@a_block Sorry for my ignorance, I had no output before just errors and then I didn't check old time.clock() anymore so I thought time.clock() does not work at all.
time.clock()
The numbers I get with the new time.process_time() are strange and every other is 0.
time.process_time()
anyway got it working with the old time.clock()
this works for now, but a error free console would be nice in the future ... or perhaps I can get my head around that decorator profilling from zipit ... still a little to much for me.
If somebody feels generous perhaps post a decorator version of
import cProfile, math, pstats, c4d def some_function(): profile = cProfile.Profile() # Start of profiling profile.enable() data = [math.sqrt(abs(math.sin(i * .001) * math.cos(i * .001))) for i in range(100000)] profile.disable() # End of profiling stats = pstats.Stats(profile) stats.strip_dirs() stats.sort_stats("cumtime") stats.print_stats() if __name__ == "__main__": c4d.CallCommand(13957) # Konsole löschen / delete console log some_function()
anyway thanks
??? So, what are the errors? I have none...
your code is not faulty, at least not in a strict sense. The problem is that you did choose time.time() for the profiling, which is not a reliable tick source in any version of Python. You can use it if you are only interested in timings above the 100 ms mark. For everything else you should cProfile. The code below demonstrates the difference and also goes a bit into the details. The bottom line is (at least from my point of view) that you cannot do what you want to do in any language, especially on Windows.
time.time()
cProfile
You might have to run the code a few times, because unreliability also means that it can work when you don't want it to ;).
Cheers, Ferdinand
#!py3 """Simple example for a profiling decorator. Okay, here are three problems at play. 1. The accuracy of the high precision system clock depends on the OS, with Windows usually being said to be substantially worse than MacOS and Linux (this ranking should be taken with a grain of salt). 2. time.time() is not very precise in general, it has been considered for depreciation in 3.X but still "lingers" for some reason unknown to me. 3. Meaningful profiling, i.e. the measuring of timings, is in general a complicated thing, when it goes below the 10-20 ms mark. This is not just a Python thing, but basically applies to anything that runs on a complex OS. Technical Solutions: time.time() is in general a bad choice for timings unless you want to measure timings in the smaller than 100 ms range. There are some "tips" out there which recommend to use something like time.perf_counter_ns() or time.process_time() instead. Which does not make much sense to me since these are the clocks time.time() is choosing from when looking for the most accurate system clock. The same thing does IMHO apply to the recommendation of using DateTime instead of time. The only reasonable way to measure timings in the smaller than 100 ms range are Python's profiling libraries, e.g. cProfile I did use above. But note, that also cProfile only grantees accuracy in the bigger than 100 ms range. Script & Stuff: The script below demonstrates, that using time.time() will sometimes return faulty timings of zero seconds, while cProfile won't do that. You might have to run the script multiple times to get such failure case, because the one-at-a-time accuracy of time.time() depends on many factors. The most reasonable thing to do here, is to move your profiling "up one level", i.e. do not measure a single call, but rather the loop in your code. This will have obviously have the same absolute error, but a much more reasonable relative error. About the "100 ms": From experience this seems to be a very conservative figure on modern Windows machines, you can actually expect ~25-50 ms. """ import cProfile import pstats import time def profile(func): """A simple profiling decorator. """ profiler = cProfile.Profile() def wrapper(*args, **kwargs): result = None try: result = profiler.runcall(func, *args, **kwargs) except Exception as error: raise error finally: stats = pstats.Stats(profiler) # To get the full profile do this. # stats.strip_dirs().print_stats() t = round(stats.total_tt, 3) print (f"{func.__name__} took {t} sec.") return result return wrapper def timing(func): """A time.time() based decorator for timings. !SHOULD NOT BE USED! """ def wrapper(*args, **kwargs): try: t = time.time() result = func(*args, **kwargs) t = round((time.time() - t), 3) except Exception as error: raise error finally: print (f"{func.__name__} took {t} sec.") return result return wrapper @profile def foo_profile(): """ """ [1/3333 for _ in range(100000)] @timing def foo_time(): """ """ [1/3333 for _ in range(100000)] def main(): """ """ # Take 10 rounds with each decorator. for _ in range(10): foo_profile() for _ in range(10): foo_time() if __name__ == "__main__": main()
What I forgot to mention is, that time.time(), only guarantees a precision of greater or equal to 1 sec. The 100 ms figure I do mention, only applies to the high precision clocks it might or might not be able to poll. Which should always happen on Windows/MacOs, but just to be clear about the precsion of time.time().
thank you both @a_block for enduring my beginner questions and zipit always keeping it precise and clean ,,,
I managed to get an old script to run 20 times faster by just finding junk I was able to cleanup ! Even though as a beginner I sometimes do not know what I am doing this profiling helps to find stupid code!
so few more scripts to cleanup.
