Syncing Object Property Update in ObjectData
I am trying to sync ObjectData parameters through XPresso, but I cannot because my Object Properties aren't being updated at the same time. To demonstrate what I mean better, I came up with a Demo project. Here is a screen capture of the result:
In this screen capture, the planes' width & height are being set with XPresso. The blue plane is using the Object's Size Percentage which is in sync with the object. I included this plane to show that it is not an issue of the XPresso tag's priority. The red plane's size is using a value that is calculated based on the Size Percentage in my ObjectData.GetVirtualObjects override. I have tried the calculation at different points of the ObjectData (e.g. the init function, before/after the
MSG_UPDATE
Message, etc.), but I'm still experiencing the lag.Here is an archive of my Demo ObjectData plugin and my scene file.
How can I make a calculation based on one parameter and update the Object Properties so that it stays in sync?
Thank you!
I do not mean to be rude, but I would really ask for putting up code in your postings rather than just images and drop-box links.
About your problem. I am not 100% sure what exactly you are trying to do, specifically the hard coded
size
attribute, thestr
that is actually anint
and more is weirding me out. But given that I do not completely misunderstand your problem, this should fix it:def __init__(self, *args): """ """ # Not neccessary. # super(DemoObject, self).__init__(*args) self._cached_value = None self.SetOptimizeCache(True) def Message(self, node, mid, data): """ """ # When a parameter has been changed. if mid == c4d.MSG_DESCRIPTION_POSTSETPARAMETER: perc = (node[c4d.DEMOOBJ_SIZE_PERCENTAGE] if node[c4d.DEMOOBJ_SIZE_PERCENTAGE] is not None else 0.5) # To avoid nasty chain reactions when Message is not called from the # main thread, which should not happen normally. if not c4d.threading.GeIsMainThread(): return True # When our percentage has changed, we have to safeguard our modification # like that to avoid chain reactions. The proper message to do all this would # actually be MSG_DESCRIPTION_VALIDATE, but this did not work out for # me, not quite sure why. if perc != self._cached_value: self._cached_value = perc data = node.GetDataInstance() data[c4d.DEMOOBJ_WIDTH] = str(self.size * float(perc) * 2.0) return True def GetVirtualObjects(self, op, hierarchyhelp): """ """ return self.CreateMyObject(op, self._cached_value or 1.)
zipit
size
attribute, thestr
zipit
@zipit I'll post code with my scenes/screenshots in the future.
Setting the value in
fixed my issue! Wow, how do you know all of this stuff??!
