Hi there! I need to get c4d.DESC_NAME of choosen modelling settings parameter. Here is a how it works for C4DAtom:
cube = doc.SearchObject('Cube') description = cube.GetDescription(c4d.DESCFLAGS_DESC_0) # Get the description of the cube object for bc, paramid, groupid in description: # Iterate over the parameters of the description print (bc[c4d.DESC_NAME], bc[c4d.DESC_IDENT],paramid ,groupid)
Also there is a Document Snap settings:
for bc in c4d.modules.snap.GetSnapSettings(doc): print bc
The result is:
(440000121, 1) (440000120, 31.0) (440000138, 0) (431000002, 1.5707963267948966) (431000020, 1) (431000005, 1) (440000131, 2.0) (440000133, 0.08726646259971647) (440000132, 0.05) (440000134, 0.01) (440000115, <c4d.BaseContainer object at 0x00000299A17F5690>) (431000000, <c4d.BaseContainer object at 0x00000299A17F5F90>) (431000001, <c4d.BaseContainer object at 0x00000299A17F5F60>) (440000117, <c4d.BaseContainer object at 0x00000299A17F5750>) (440000129, <c4d.BaseContainer object at 0x00000299A17F5AE0>) (1007, 1) (1008, 1) (1011, 1)
There is a way to recive Description "container" for Modelling Settings? Thanks!
Hi @mikeudin this can be done with the next code:
import c4d def GetModelingNode(): ID_SNAP_SCENEHOOK = 440000111 snapSceneHook = doc.FindSceneHook(ID_SNAP_SCENEHOOK) for branch in snapSceneHook.GetBranchInfo(c4d.GETBRANCHINFO_NONE): if branch["name"] == "MdSH": if branch["head"] is not None: return branch["head"].GetFirst() raise RuntimeError("Unable to find the Modeling Node") def main(): mod = GetModelingNode() for bc, paramid, groupid in mod.GetDescription(c4d.DESCFLAGS_DESC_0): print (bc[c4d.DESC_NAME], bc[c4d.DESC_IDENT],paramid ,groupid) # Execute main() if __name__=='__main__': main()
Cheers, Maxime.
Great! Thank very much @m_adam!
