Hey everyone,
I'm currently working on a plugin to establish a neat connection between C4D and Houdini. ( https://twitter.com/lasse_lauch/status/1319296533016182787?s=20 )
However, one thing that always drives me insane when transferring data between different apps is the matrix-rotation-euler-quaternion-endless-rabbit-hole when animation comes into play.
Currently I'm using these functions from the documentation as a base...
def GetGlobalPosition(obj): return obj.GetMg().off def GetGlobalRotation(obj): return c4d.utils.MatrixToHPB(obj.GetMg(), #order=c4d.ROTATIONORDER_XYZGLOBAL !? ) def GetGlobalScale(obj): m = obj.GetMg() return c4d.Vector( m.v1.GetLength(), m.v2.GetLength(), m.v3.GetLength())
... and write the components into a dict like:
dict
myDict[frame]['tx'] = pos.x myDict[frame]['ty'] = pos.y myDict[frame]['tz'] = pos.z myDict[frame]['sx'] = scale.x myDict[frame]['sy'] = scale.y myDict[frame]['sz'] = scale.z # getter in cinema4D (rotation in radians) myDict[frame]['rx'] = rot.x myDict[frame]['ry'] = rot.y myDict[frame]['rz'] = rot.z # setter in houdini (radians to degrees): hou.hmath.radToDeg(key['rx'])
But I'm sure I somehow need to deconstruct the matrix and reconstruct in houdini.
(BTW - For my AEC4DPRO plugin we've found a solution after working closely with @r_gigante in using the c4d.utils.GetOptimalAngle(hpb_old, hpb_new, rotation_order function as described -> here...
Is this the way to go in general, or are there some other pointers to break this down to it's bare bones... I'm looking at you: @zipit … HELP!
When it comes to Matrices and Rotations my brain sloooowly starts to melt…… (…and yes, I've watched the 3Blue1Brown videos on quaternions... )
Would love to provide further code details if needed.
Thanks, Lasse
I am not sure if I am able to be of great help, because I do not know much about Houdini (cool project btw ;)).
c4dpy
hou.Quaternion
Cheers, zipit
[1] https://en.m.wikipedia.org/wiki/Orientation_(vector_space) [2] https://www.sidefx.com/docs/houdini/hom/hou/Quaternion.html
Hi @lasselauch , nice to see you again around.
About your question on transferring object transformation to Houdini, given that I've no clue on the communication mechanism you've setup, I agree with @zipit that you should use transformation matrixes to transfer data from C4D to Houdini and pay attention to coordinate system handedness matching.
A right handed coordinate system can be converted to a left handed coordination system (or vice-versa) by:
Cheers, Riccardo
Hey guys,
just wanted to let you know, that I've cracked the case in the meantime.
Here are my findings:
def convert_matrix_left_to_right(m): # http://www.techart3d.com/2016/02/convert-left-handed-to-right-handed-coordinates/ # m = op.GetMg() new_m = c4d.Matrix( m.off, m.v1*-1, m.v2, m.v3) return new_m def rotate_y_axis_180(): # Construct your own matrix based on rotation of axis # https://www.mathworks.com/help/phased/ref/roty.html x = c4d.Vector(-1, 0, 0) y = c4d.Vector(0, 1, 0) z = c4d.Vector(0, 0, -1) off = c4d.Vector(0, 0, 0) return c4d.Matrix(off, x, y, z) def GetGlobalRotation(obj): m = obj.GetMg() new_m = rotate_y_axis_180() * convert_matrix_left_to_right(m) return c4d.utils.MatrixToHPB(new_m, order=c4d.ROTATIONORDER_XYZGLOBAL)
Indeed you have to convert from a left-handed (c4d) (hpb) to a right-handed (houdini) (xyz) coordinate system... plus I've found that you need to add 180° to the y axis, so I constructed a matrix in rotate_y_axis_180 that I can multiply to my converted matrix.
rotate_y_axis_180
Hope it helps someone...
Thank you guys for your input! Have a great weekend and stay safe!
Cheers, Lasse
