Remove a GeDialog Tab Group
I'm trying to remove a GeDialog Tab Group. Is this possible without flushing the Layout and redrawing all of the groups? Thank youimport c4d from c4d import gui PLUGIN_ID = 123456 MAIN_GROUP = 10000 GROUP_1 = 10001 GROUP_2 = 10002 GROUP_BTN = 10003 TEXT_1 = 2001 TEXT_2 = 2002 DELETE_GRP_BTN = 2003 class MyDialog(c4d.gui.GeDialog): def CreateLayout(self): self.SetTitle("Remove Group") if self.TabGroupBegin(MAIN_GROUP, c4d.BFH_SCALEFIT | c4d.BFV_SCALEFIT, tabtype=c4d.TAB_TABS): if self.GroupBegin(GROUP_1, c4d.BFH_SCALEFIT | c4d.BFV_SCALEFIT, 3, 0, "Group 1"): self.GroupBorderSpace(10,10,10,10) self.AddStaticText(TEXT_1, c4d.BFH_SCALEFIT | c4d.BFV_SCALEFIT, 0, 0, "Group 1", c4d.BORDER_THIN_IN) self.GroupEnd() if self.GroupBegin(GROUP_2, c4d.BFH_SCALEFIT | c4d.BFV_SCALEFIT, 3, 0, "Group 2"): self.GroupBorderSpace(10,10,10,10) self.AddStaticText(TEXT_2, c4d.BFH_SCALEFIT | c4d.BFV_SCALEFIT, 0, 0, "Group 2", c4d.BORDER_THIN_IN) self.GroupEnd() self.GroupEnd() if self.GroupBegin(GROUP_BTN, c4d.BFH_SCALEFIT | c4d.BFV_BOTTOM, 0, 0, ""): self.GroupBorderSpace(10,10,10,10) self.AddButton(DELETE_GRP_BTN, c4d.BFH_LEFT, initw=0, inith=0, name='DELETE') self.GroupEnd() return True def Command(self, id, msg): if id == DELETE_GRP_BTN: self.RemoveElement(GROUP_1) self.LayoutChanged(MAIN_GROUP) #self.SetInt32(MAIN_GROUP, GROUP_2) return True if __name__=='__main__': global myDlg myDlg = MyDialog() myDlg.Open(dlgtype=c4d.DLG_TYPE_ASYNC, xpos=-2, ypos=-2, \ pluginid=PLUGIN_ID, defaultw=400, defaulth=350)
Hi @blastframe unfortunately, in Python there is no way, and you are right the correct thing is to flush and regenerate all the layout.
This is for sure not possible in Python, in C++ it may be possible via UpdateDialogHelper.
If you are interested in a C++ solution I can look further.Cheers,
@m_adam I'm good with using Python this way. Thanks Maxime.
