Issue dragging a pyTag with a message function > Type-/SystemError in R23/Python3 on both Mac&PC.
It took me a while to figure out which part caused the problem converting a scripting tag from py2 to py3...
The console printed the following errors (multiple times at a time):TypeError: Expected PyCapsule, not None
The above exception was the direct cause of the following exception:
SystemError: PyEval_EvalFrameEx returned a result with an error setThe problem was the message function (I think..). Did a simple test with a pyTag containing only 1 userData button and the following script:
import c4d def main(): pass def message(id, data): if id == c4d.MSG_DESCRIPTION_COMMAND: id2 = data['id'][0].id if id2 == c4d.ID_USERDATA: userDataId = data['id'][1].id if userDataId == 1: tst() def tst(): print ("tst")
_Copying an object with the pyTag - no problem.
_Yes, the button just prints “tst” in python2 & 3 :}
_Dragging in python2 - no problem.
_Dragging the pyTag to another object (or a duplicate onto itself) in R23 - gives 2 errorsHow can I solve this? I guess it's not the wisest idea in the world to put a SystemError in a try-except block...
Tia, Jochem
I saw the following code in the “python3_migration” in the SDK mentioning the "PyCapsule", but It doesn’t make much sense to me :{
PyCObject_AsVoidPtr is replaced by PyCapsule_GetPointer
_next code is only compatible in Python 2.7
P1MSG_UN = msg.GetVoid(c4d.BFM_CORE_PAR1)
pythonapi.PyCObject_AsVoidPtr.restype = c_int
pythonapi.PyCObject_AsVoidPtr.argtypes = [py_object]
P1MSG_EN = pythonapi.PyCObject_AsVoidPtr(P1MSG_UN)_next code is only compatible in 3.7
P1MSG_EN = pythonapi.PyCapsule_GetPointer(P1MSG_UN, None)
Hi, as a workaround you could add the next code in your message function.
import ctypes def message(id, data): if id == c4d.MSG_DRAGANDDROP: ctypes.pythonapi.PyCapsule_New.restype = ctypes.py_object capsule = ctypes.pythonapi.PyCapsule_New(b"", b"data", None) data["data"] = capsule
Note, this issue may not only affect the Python Tag but any Python BaseList2D which can interact with
MSG_DRAGANDDROP
, so even your Python TagData could cause the issue.Keep in mind this is an internal bug, which will be fixed in a future update of Cinema 4D.
Hi @jochemdk, this is an internal bug, nothing you can fix, unfortunately, note that you can ignore them normally the Tag should work as expected.
I've opened a bug report about it.
Have a same issue.
There is a workaround to avoid Error messages?
MSG_DRAGANDDROP
This post is deleted!
Thx for your replies! I'll test it soon & hopefully the bug will be fixed :)
without further feedback, we will consider this thread as solved by Wednesday and flag it accordingly.
@zipit
Yes, thx - the system works :}
Hi @jochemdk,
okay, I then took the liberty to close the question ;) You can of course still post here.
