I compiled my plugin for R23 on a PC and no problems. Now I want to do the same on the Mac (10.15.6) using Xcode 11.3.1.
I copied the sdk and the ran R23 projecttool to /Documents. Everything seems ok, plugins.xcode was created and looks good.
Again, I am doing everything in my Documents folder, so I should not have any protection / privilege issues. But I get the following IOError.
projectdefinition.txt
Even compiling everything from default (microsdk) gave an error:
error: Build input file cannot be found: '/Users/pgrooff/Documents/R23_sdk/sdk_R23.008/frameworks/core.framework/generated/hxx/register.cpp' (in target 'core.framework' from project 'core.framework')
I downloaded and installed everything from scratch. I am using Mac 10.15.6 and Xcode 11.3.1.
Here the folder structure.
After "The default interactive shell is now zsh. To update your account to use zsh, please run chsh -s /bin/zsh."
chsh -s /bin/zsh
I started Xcode, did a "Clean Build Folder" and compiled again.
Success! So, I had to do a lot of compiles, before I had success. I guess the hxx files were not generated yet.
I will now try my own plugin.
I now changed projectdefinition.txt to compile my own plugin, but i keep getting
File "/Users/pgrooff/Documents/R23_sdk/sdk_R23.008/frameworks/settings/sourceprocessor/declarations.py", line 123, in writeToFile f = open(file, 'w') IOError: [Errno 1] Operation not permitted: '/Users/pgrooff/Documents/R23_sdk/sdk_R23.008/plugins/getloglines/generated/sourceprocessor.stamp' Command PhaseScriptExecution failed with a nonzero exit code
Is the sequence of building correct?
Ok, success. Copying the plugin folder from pc to mac was the issue!
