Exception: no converter found for 'net.maxon.interface.url-C[A]'
Hello
I have installed R23 demo.
I am trying to get the documents List with :
c4d.documents.GetRecentDocumentsList(isBodyPaint=False)
but instead of getting the list, I got an exception error printed in the console :
Is it a bug ?
ThanksP.S.: others c4d.documents methods are working well :
if doc.GetDocumentName()== "PyRubik": pass else: li_docs = c4d.documents.GetRecentDocumentsList(isBodyPaint=False) **# <-- pb here** li_noms = [d.GetDocumentName() for d in li_docs] if "PyRubik" not in li_noms: # create a new doc projet = c4d.documents.BaseDocument()# new doc projet.SetDocumentName("PyRubik") c4d.documents.InsertBaseDocument(projet) c4d.documents.SetActiveDocument(projet)# PyRubik active else: projet = li_docs[li_noms.index("PyRubik")] # to obtain PyRubik object c4d.documents.SetActiveDocument(projet) # to make "PyRubik" active
Hi Patrice, thanks for reaching out to us.
With regard to your question, on obtaining the list of opened documents, the solution is pretty easy and consists in getting the first document and iterating over the others.
activeDoc = c4d.documents.GetFirstDocument() while activeDoc is not None: print (activeDoc.GetDocumentName()) activeDoc = activeDoc.GetNext()
Instead with regard to the first issue, you have to include in your script the proper include statement
import c4d, maxon # Main function def main(): li_docs = c4d.documents.GetRecentDocumentsList(isBodyPaint=False) for i in range (li_docs.GetCount()): print (li_docs[i])
Cheers, R
Hello
I saw that : c4d.documents.GetRecentDocumentsList(isBodyPaint=False) is for the recent document list but not to get the current document list (opened projects).
I am not able to find in SDK documentation any method to get the list of opened documents.
Need help please.
Thanks
Patrice
Cheers, R
without further feedback, we will consider this thread as solved by Wednesday and flag it accordingly.
