Adding Keyboard Message: KEY_ENTER & KEY_TAB
I would like to request thatKEY_ENTER
andKEY_TAB
are added to the Keyboard Message's Channel.This issue has come up several times in the forum. There are some workarounds, it seems, but they aren't nearly as straightforward as checking the Channel's value:
I'm sure there are reasons those two keys weren't included, but it would be very helpful if this implementation could be revisited.
For anyone facing this issue, here are some workarounds in a script:
import c4d from c4d import gui GROUP_ID1=1000 TEXT_FIELD=1001 class KeyDlg(gui.GeDialog): def CreateLayout(self): self.SetTitle("Key Test") if self.GroupBegin(GROUP_ID1, c4d.BFH_SCALEFIT | c4d.BFV_SCALEFIT, 1, 1): self.GroupBorderNoTitle(c4d.BORDER_THIN_IN) self.AddStaticText(TEXT_FIELD, c4d.BFH_CENTER | \ c4d.BFH_SCALE | c4d.BFV_CENTER | c4d.BFV_SCALE, 0, \ 0, "Press the Enter Key") self.GroupEnd() return True def Message (self, msg, result): if msg.GetId() == c4d.BFM_INTERACTSTART: bc = c4d.BaseContainer() if c4d.gui.GetInputState(c4d.BFM_INPUT_KEYBOARD, c4d.KEY_TAB, bc): if bc[c4d.BFM_INPUT_VALUE] == 1: print(c4d.KEY_TAB,"Tab") self.SetString(TEXT_FIELD,"Tab") self.LayoutChanged(TEXT_FIELD) return True if c4d.gui.GetInputState(c4d.BFM_INPUT_KEYBOARD, c4d.KEY_ENTER, bc): if bc[c4d.BFM_INPUT_VALUE] == 1: print(c4d.KEY_ENTER,"Enter") self.SetString(TEXT_FIELD,"Enter") self.LayoutChanged(TEXT_FIELD) return True if msg.GetId() == c4d.BFM_INPUT: if msg.GetInt32(c4d.BFM_INPUT_DEVICE) == c4d.BFM_INPUT_KEYBOARD: channel = msg.GetInt32(c4d.BFM_INPUT_CHANNEL) txt = msg.GetString(c4d.BFM_INPUT_ASC) if channel == c4d.KEY_SPACE: txt = "Space" elif channel == c4d.KEY_LEFT: txt = "Left" elif channel == c4d.KEY_RIGHT: txt = "Right" elif channel == c4d.KEY_UP: txt = "Up" elif channel == c4d.KEY_DOWN: txt = "Down" print(channel,txt) self.SetString(TEXT_FIELD,txt) self.LayoutChanged(TEXT_FIELD) return True return gui.GeDialog.Message(self, msg, result) dlg = KeyDlg() dlg.Open(c4d.DLG_TYPE_MODAL, defaultw=300, defaulth=50)
Thank you!
thats a nice one, thank you!
enter and tab works!
can't get the last part to work here, tough (c4d.BFM_INPUT)
@indexofrefraction I just tested and it works with my setup. Most of the code comes from former SDK team member Andreas' post here. Perhaps test that? If it doesn't work, I would open a new thread.
I'd prefer to keep this topic on the
KEY_ENTER
&KEY_TAB
request please.
hi,
@indexofrefraction, as @blastframe said, let's keep that thread clean and ask your question in another thread, this is working on my system.
@blastframe , we will take into consideration your request.
Manuel
