I am working on limited C4D python api understanding, so forgive what may be an noob question.
I am building a specialized script for my personal workflow to extract parameter data from a project build. The goal being that it loops through all the scene objects, tags, and parameters, then checks if parameter is not default (or has been changed), then returns a tab delimited string consisting of Object name / Parameter name / Parameter Value
The resulting list I like to use as a notes reference for when I make my video tutorials. It helps me remember what I changed to achieve final result. So only the changed parameters are required.
Currently I have the Object/parameter loop, name & value retrieval functioning by cobbling together some snippets I've found online, and from my own knowledge. Some checks and adjustments made to results along the way as well. What I am having issues with are the parameter description name attributes located in this list: https://developers.maxon.net/docs/Cinema4DPythonSDK/html/modules/c4d/Description/index.html#c4d.Description
So far I have tried using changed and default to check parameter, but both fail and return None instead of True/False I assume I am using them improperly or there may be a limitation to how I want to use them. As I read in the help docs (url above), changed returns bool if entry is changed, and default returns the parameter default value. Changed would be an easier use, but if I have to do a...
default != "value"
...kind of check, that's ok too.
c4d.DESC_CHANGED c4d.DESC_DEFAULT
Any insight as to how I can check for a parameter that in not default or has changed would be appreciated.
This is the code I have so far, and I am aware that some parameters that are Gradients, Time, Custom, etc.. are not handled with this code currently. Next hurdle to cross when I get to that though.
import c4d from c4d import gui # Main function def main(): o = op if o is not None: recurse(o) def recurse(o): obj = o if obj is not None: #Misc variables tab = "\t" #Header print "Name\tParameter\tValue\tParam ID" #Print object name on = obj.GetName() print on #Print object PSR print on + "\t" + "Position\t" + str(obj[c4d.ID_BASEOBJECT_REL_POSITION]) print on + "\t" + "Scale\t" + str(obj[c4d.ID_BASEOBJECT_REL_SCALE]) print on + "\t" + "Rotation\t" + str(obj[c4d.ID_BASEOBJECT_REL_ROTATION]) print on + "\t" + "Vis Editor\t" + str(obj[c4d.ID_BASEOBJECT_VISIBILITY_EDITOR]) print on + "\t" + "Vis Renderer\t" + str(obj[c4d.ID_BASEOBJECT_VISIBILITY_RENDER]) #Display color check/conversion and print uc = obj[c4d.ID_BASEOBJECT_USECOLOR] if uc == 2: dc = obj[c4d.ID_BASEOBJECT_COLOR] print on + "\t" + "Display Color\tVector(" + str(dc[0]*255) + ", " + str(dc[1]*255) + ", " + str(dc[2]*255) + ")" #Get object data data = obj.GetData() #Get object description description = obj.GetDescription(c4d.DESCFLAGS_DESC_0) for bc, paramid, groupid in description: #Process object parameters isgroup = paramid[0].dtype==c4d.DTYPE_GROUP if isgroup: continue group = groupid[0].id filtergroup = group!=c4d.Tbaselist2d and group!=c4d.FALLOFF_GROUPFALLOFF idname = bc[c4d.DESC_IDENT] if idname: filtergroup = filtergroup and not idname.startswith("ID_BASEOBJECT") if filtergroup: if bc[c4d.DESC_NAME] and bc[c4d.DESC_IDENT]: #------------------------------------------- #ATTEMPTS TO CHECK FOR PARAMETER CHANGED OR DEFAULT #------------------------------------------- #Fails to return changed correctly #if bc[c4d.DESC_CHANGED] == 1: #Fails to return default correctly #if bc[c4d.DESC_DEFAULT] == 1: #------------------------------------------- try: #Adjust color float to 255 range vec = obj[paramid] if "Color" in bc[c4d.DESC_NAME] and "Vector" in str(vec): vec = obj[paramid] val = "Vector(" + str(vec[0]*255) + ", " + str(vec[1]*255) + ", " + str(vec[2]*255) + ")" else: val = str(obj[paramid]) print on + "\t" + bc[c4d.DESC_NAME] + "\t" + val except: print on + "\t" + bc[c4d.DESC_NAME] + ": PARAMETER REQUIRES MANUAL EXTRACTION" #Get object tags tags = obj.GetTags() for t in tags: tn = t.GetTypeName() if tn is not "" or None: #Add spacer in output print "" #Get tag name print t.GetTypeName() try: #Process tag parameters tdesc = t.GetDescription(c4d.DESCFLAGS_DESC_0) for bc, paramid, groupid in tdesc: #------------------------------------------- #ATTEMPTS TO CHECK FOR PARAMETER CHANGED OR DEFAULT #------------------------------------------- #Fails to return changed correctly #if tn[c4d.DESC_CHANGED] == 1: #Fails to return default correctly #if tn[c4d.DESC_DEFAULT] == 1: #------------------------------------------- isgroup = paramid[0].dtype==c4d.DTYPE_GROUP if isgroup: continue group = groupid[0].id filtergroup = group!=c4d.Tbaselist2d and group!=c4d.FALLOFF_GROUPFALLOFF idname = bc[c4d.DESC_IDENT] if idname: filtergroup = filtergroup and not idname.startswith("ID_BASEOBJECT") if filtergroup: if bc[c4d.DESC_NAME] and bc[c4d.DESC_IDENT]: try: #val = tn+"[c4d."+str(idname)+"]" print tn + "\t" + bc[c4d.DESC_NAME] + "\t" + str(t[paramid]) except: print tn + "\t" + bc[c4d.DESC_NAME] + ": PARAMETER REQUIRES MANUAL EXTRACTION" except: print "--UNKNOWN PARAMETER--" #Check for child object d = obj.GetDown() if d is not None: recurse(d) #Get next object n = obj.GetNext() if n is not None: recurse(n) else: print "Error: Select one starting object first." # Execute main() if __name__=='__main__': main()
Hi @davidtorno sorry I overlooked the version in the post tag. You are right ID_BASELIST_ICON_COLOR was added in R21. So you could remove it.
Regarding the second issue, you are also right, a PolygonObject/SplineObject have no history at all, so you can't trace them, even modeling operation done on them can't be retrieved at least by the way I propose. You could do a SceneHook(only available in C++) to monitor the change made by a tool by listening to EVMSG_CHANGE (triggered when a EventAdd is processed) figured out if a polygon object changed (by iterating over each scene object, and checking their dirty bits), then retrieve the current tool and parameters, but as you can see it's a pretty complex task.
So in your case I would suggest to simply ignore edited object (so PolygonObject and SplineObject) by editing ignoredObjs variable like so
ignoredObjs = [c4d.Opolygon, c4d.Opoint, c4d.Ospline, c4d.Oline]
Cheers, Maxime.
welcome to the forum. If I understand your posting correctly, your question is how to test if a description parameter has been modified in respect to its default value. Your code is almost there, but you probably misconstrued c4d.DESC_DEFAULT as a boolean indicating a changed value, but it is actually the actual default value. So to test if the parameter has been modified, it would be something like this:
c4d.DESC_DEFAULT
description = node.GetDescription(c4d.DESCFLAGS_DESC_0) for bc, descid, _ in description: # Test if the current value is identical to the default value. is_default = bc[c4d.DESC_DEFAULT] == node[descid]
Cheers, zipit
@zipit said in [python] Parameter Description Access not working as expected:
Correct, I understood it as indicating a changed value. Good to know. These are the nuances I am still adjusting to with C4D python. Thanks for the answer and explanation. I will give this a go tomorrow when I’m back on my machine. I appreciate your help.
after reading your reply I realised, that I probably should have also mentioned that Cinema has a dirty system, which will let you check if an object has been modified. It is scattered over multiple classes, but most of it is attached to C4DAtom, with the major method being C4DAtom.GetDirty.
C4DAtom
C4DAtom.GetDirty
@zipit So I have tried implementing your check for DESC_DEFAULT and I am still not getting values for default.
#.....Snippet from my script, full code at bottom of post. #Process tag parameters desc = o.GetDescription(c4d.DESCFLAGS_DESC_0) for bc, paramid, groupid in desc: #Check if current value matches default value is_default = bc[c4d.DESC_DEFAULT] == o[paramid] #print both values for visual comparison print "DEBUG:: " + str(bc[c4d.DESC_DEFAULT]) + " == " + str(o[paramid]) + " --> " + str(is_default) if is_default is not True: #.....
As an example I am currently using a simple Null object for testing the default functionality. Changing only the Object > Display parameter to see if my code catches if it is set to default or not. The print output is like this so far. For simplicity I've only posted the Object Properties results.
Object Properties DEBUG:: None == 0 --> False Display 0 DEBUG:: None == 10.0 --> False Radius 10.0 DEBUG:: None == 10.0 --> False Aspect Ratio 10.0 DEBUG:: None == 0 --> False Orientation 0
I would expect this debug result to read as this since all parameters are at their defaults.
Object Properties DEBUG:: 0 == 0 --> True DEBUG:: 10.0 == 10.0 --> True DEBUG:: 10.0 == 10.0 --> True DEBUG:: 0 == 0 --> True #...
...but bc[c4d.DESC_DEFAULT] is continuously returning None for some reason. What am I missing here? Thanks again for any assistance on this.
Here is my full script code currently. I cleaned up a lot from previous build as it was getting very messy. The param name/value retrieval is now it's own function (def):
import c4d from c4d import gui # Main function def main(): o = op if o is not None: recurse(o) def getParamData(o): try: #misc var grpName = "" #Process tag parameters desc = o.GetDescription(c4d.DESCFLAGS_DESC_0) for bc, paramid, groupid in desc: #Check if current value matches default value is_default = bc[c4d.DESC_DEFAULT] == o[paramid] #print both values for visual comparison print "DEBUG:: " + str(bc[c4d.DESC_DEFAULT]) + " == " + str(o[paramid]) + " --> " + str(is_default) if is_default is not True: isgroup = paramid[0].dtype==c4d.DTYPE_GROUP if isgroup: #handle blank names if bc[c4d.DESC_NAME] is not "": grpName = bc[c4d.DESC_NAME] print grpName #check for param name and ident if bc[c4d.DESC_NAME] and bc[c4d.DESC_IDENT]: try: #Adjust color float to 255 range vec = o[paramid] if "Color" in bc[c4d.DESC_NAME] and "Vector" in str(vec): vec = o[paramid] val = "Vector(" + str(vec[0]*255) + ", " + str(vec[1]*255) + ", " + str(vec[2]*255) + ")" else: #Strip None values out blank = o[paramid] if blank == None: val = "" else: val = str(o[paramid]) #handle group name duplicates in results if bc[c4d.DESC_NAME] == grpName: pass else: print "\t" + bc[c4d.DESC_NAME] + "\t" + val except: print "\t" + bc[c4d.DESC_NAME] + ": PARAMETER REQUIRES MANUAL EXTRACTION" except: print "--UNKNOWN PARAMETER--" def recurse(o): obj = o if obj is not None: #Misc variables tab = "\t" #Header print "Name\tParameter\tValue\tParam ID" #Print object name on = obj.GetName() print on #Get object data #data = obj.GetData() #Get param name and value getParamData(obj) #Get object tags tags = obj.GetTags() #Loop tags for t in tags: tn = t.GetTypeName() if tn is not "" or None: #Add spacer in output print "" #Get tag name print t.GetTypeName() #Get param name and value getParamData(t) #Check for child object d = obj.GetDown() if d is not None: recurse(d) #Get next object n = obj.GetNext() if n is not None: recurse(n) else: print "Error: Select one starting object first." # Execute main() if __name__=='__main__': main()
the problem you are running into, is that the default value is an optional description element flag. If no such flag has been provided by the author who wrote the description markup, the element will fall back to the internal default value of that type (e.g. 0 for an integer). This value however won't be reflected in the DESC_DEFAULT field of a Description object, it will return None in this case, like you experienced it in your tests.
0
DESC_DEFAULT
Description
None
You would have to either handle that case manually or use the dirty checksums that I did mention. The problem there is that you can test the data container of a node for being dirty, i.e. its parameters, and by that detect if a parameter has been modified, but not exactly which one of the parameters has been modified.
@zipit said in Parameter Description Access not working as expected:
Hmmm, bummer. Ya the whole goal was to only return parameters not at default value. I've made similar scripts for Houdini, and After Effects. Cinema4D was my last holdout.
I'll take a look at the dirty checksums. If I can at least tell if something was changed, it's better than nothing I guess.
Thanks again for the help.
Still far from being fully fleshed out, but could prove helpful to others in some form possibly. It's totally specific to my needs so I make no claims of it's longevity, stability, or usability for anyone else's needs.
The script prints to the console a tab delimited list of all project objects beginning with a selected object. It then loops downwards through all objects, object parameters, tags, and tag parameters gathering names & values. Choose top most object in your project to get all items in your project.
Here's the code I'm settling on for the moment. I did a few common parameter conversions from numerical value to it's string value seen in the UI.
Example 1: Toggle switches return "Unchecked" / "Checked" instead or 0 / 1 Example 2: Visible in Editor / Renderer return "On" / "Off" / "Default" instead of 0 / 1 / 2
Source code:
#-------------------------------------------------------- # [IN DEVELOPEMENT AND NOT COMPLETED YET] # Project parameter names and values list script # 9/2020 David Torno #-------------------------------------------------------- import c4d from c4d import gui # Main function def main(): o = op if o is not None: recurse(o) def getParamData(o): try: #-------------------------------------------------------- # PARAMETER DATATYPE NUMBERS R20 (Likely to change with C4D versions) # 1 = Group # 8 = Button # 12 = String # 15 = Dropdown # 133 = Object Link # 1000481 = Color Gradient # 1009290 = InExclude List # 400006001 = Toggle #-------------------------------------------------------- #misc var grpName = "" #Rotation Order conversion rotOrder = ["XYZ", "XZY", "YXZ", "YZX", "ZXY", "ZYX", "HPB"] #Vis in editor/renderer conversion visEditRender = ["On", "Off", "Default"] #Toggle conversion tog = ["Unchecked", "Checked"] #Process tag parameters desc = o.GetDescription(c4d.DESCFLAGS_DESC_0) for bc, paramid, groupid in desc: #print str(paramid[0].id), str(paramid[0].dtype), str(paramid[0].creator) #------------------------------------------------------- #Currently checking for default parameter value does not work #------------------------------------------------------- #Check if current value matches default value #is_default = bc[c4d.DESC_DEFAULT] == o[paramid] #print both values for visual comparison #print "DEBUG:: " + str(bc[c4d.DESC_DEFAULT]) + " == " + str(o[paramid]) + " --> " + str(is_default) #if is_default is not True: #------------------------------------------------------- isgroup = paramid[0].dtype==c4d.DTYPE_GROUP if isgroup: #handle blank names if bc[c4d.DESC_NAME] is not "": grpName = bc[c4d.DESC_NAME] print "\t" + grpName #check for param name and ident if bc[c4d.DESC_NAME] and bc[c4d.DESC_IDENT]: try: #Adjust color float to 255 range vec = o[paramid] if "Color" in bc[c4d.DESC_NAME] and "Vector" in str(vec): vec = o[paramid] val = "Vector(" + str(vec[0]*255) + ", " + str(vec[1]*255) + ", " + str(vec[2]*255) + ")" else: blank = o[paramid] if blank == None: val = "" else: val = str(o[paramid]) #Convert toggle value to name str if str(paramid[0].dtype) == "400006001": val = tog[o[paramid]] #Convert dropdown value to name str if str(paramid[0].dtype) == "15": if "Visible in " in bc[c4d.DESC_NAME]: val = visEditRender[o[paramid]] elif "Rotation Order" == bc[c4d.DESC_NAME]: val = rotOrder[o[paramid]] #handle group name duplicates in results if bc[c4d.DESC_NAME] == grpName or paramid[0].dtype == 8: pass else: print "\t\t" + bc[c4d.DESC_NAME] + "\t" + val #-------------------------------------------------------------------- #DEBUG print reveals parameter data type enumeration #-------------------------------------------------------------------- #print "DTYPE:" + str(paramid[0].dtype) + "\t\t" + bc[c4d.DESC_NAME] + "\t" + val except: print "\t\t" + bc[c4d.DESC_NAME] + ": PARAMETER REQUIRES MANUAL EXTRACTION" #-------------------------------------------------------------------- #DEBUG print reveals parameter data type enumeration #-------------------------------------------------------------------- #print "DTYPE:" + str(paramid[0].dtype) + "\t\t" + bc[c4d.DESC_NAME] + ": PARAMETER REQUIRES MANUAL EXTRACTION" except: print "--UNKNOWN PARAMETER--" def recurse(o): obj = o if obj is not None: #Misc variables tab = "\t" #Header #print "Name\tParameter\tValue\tParam ID" #Print object name on = obj.GetName() print on #Get param name and value getParamData(obj) #Get object tags tags = obj.GetTags() #Loop tags for t in tags: tn = t.GetTypeName() if tn is not "" or None: #Add spacer in output print "" #Get tag name print t.GetTypeName() #Get param name and value getParamData(t) #Check for child object d = obj.GetDown() if d is not None: recurse(d) #Get next object n = obj.GetNext() if n is not None: recurse(n) else: print "Error: Select one starting object first." # Execute main() if __name__=='__main__': main()
Example output:
Right fill light Basic Properties Name Right fill light Layer Visible in Editor Off Visible in Renderer Default Use Color 0 Display Color Vector(255.0, 255.0, 255.0) Enabled Checked X-Ray Unchecked Icon Color Unchecked Coordinates Position Vector(337.76, 0, -211.712) Scale Vector(1, 1, 1) Rotation Vector(1.326, 0, -1.571) Rotation Order HPB Quaternion Quaternion Rotation Unchecked Freeze Transformation Frozen Position Vector(0, 0, 0) Frozen Scale Vector(1, 1, 1) Frozen Rotation Vector(0, 0, 0) Global Position Vector(337.76, 0, -211.712) Global Rotation Vector(1.326, 0, -1.571) Transformed Position Vector(337.76, 0, -211.712) Transformed Scale Vector(1, 1, 1) Transformed Rotation Vector(1.326, 0, -1.571) Object Properties General Color Vector(153.765, 216.8775, 229.5) Use Temperature Unchecked Color Temperature 6500.0 Intensity 0.65 Type 8 Shadow 2 Visible Light 0 No Illumination Unchecked Show Illumination Checked Ambient Illumination Unchecked Show Visible Light Checked Diffuse Checked Show Clipping Checked Specular Checked Separate Pass Unchecked GI Illumination Checked Export to Compositing Checked Details Use Inner Value Checked Inner Angle 0.0 Inner Radius 0.0 Outer Angle 0.523598775598 Outer Radius 600.0 Aspect Ratio 1.0 Contrast 0.0 Shadow Caster Unchecked Area Shape 1 Object Size X 1200.0 Size Y 1200.0 Size Z 200.0 Falloff Angle 3.14159265359 Infinite Angle 0.00872664625997 Samples 40 Add Grain (Slow) Unchecked Show in Render Unchecked Show as Solid in Viewport Unchecked Show in Specular Checked Show in Reflection Unchecked Visibility Multiplier 1.0 Falloff 0 Falloff Inner Radius 0.0 Falloff Radius / Decay 500.0 Colored Edge Falloff Unchecked Z Direction Only Unchecked Use Gradient Unchecked Color <c4d.Gradient object at 0x000000D7967B9570> Use Near Clipping Unchecked Near Clipping from 0.0 Near Clipping to 10.0 Use Far Clipping Unchecked Far Clipping from 90.0 Far Clipping to 100.0
thanks for sharing, it is always nice if someone does that. I haven't red all your code and also did not run it, but I think the following points should be made:
# You should not type test like that, because it is bound to go wrong at # some point. if "Vector" in str(vec): pass # Either do this, which will test for 'vec' being exactly of type c4d.Vector # or c4d.Vector4d: if type(vec) in (c4d.Vector, c4d.Vector4d): pass # Or do this, which will test if 'vec' is also of type c4d.Vector or # c4d.Vector4d, i.e. is respecting polymorphism. Which does not make much # sense here, since both Vector and Vector4d are atomic types. # This however is the recommended approach to type tesing in Python, because # usually you want and need to respect polymorphism. if isinstance(vector, (c4d.Vector, c4d.Vector4d)): pass # Also your string handling is more complicated than it needs to be (you should # also stick to PEP8, specifically the line length here): val = ("Vector(" + str(vec[0]*255) + ", " + str(vec[1]*255) + ", " + str(vec[2]*255) + ")") # Use Pythons string formating instead, the values will be put in consecutive # order into the curly brackets. There is a whole string formating mini # language, which will allow you to do all sorts of stuff, like aligning text, # converting between number formats and more. Check the Python docs on the # subject if you want to know more. print "Vector(r:{}, g:{}, b:{})".format(int(vec.x * 255), int(vec.y * 255), int(vec.z * 255))
@zipit Thanks! All great points. I was trying to check for instance of object initially, but was failing to find the correct syntax in this case. I got impatient and started hacking together solutions that still function even if not optimized/ideal.
I am so use to Adobe ExtendScript which is JavaScript based and Houdini VEX which is more python/JavaScript like, and their hscript which is Python based. So C4D python syntax can be just close enough to drive me nuts when I don’t find the correct answer. I’ve struggled with C4D python for a long time too. The docs really get confusing fast (for me at least)
One thing that helped me with Adobe ExtendScript is the object model graph they have in the docs. It showed the object flow hierarchy and each class name. So it was super easy to find every method and attribute associated with each. Almost linear in nature. I think also what help most was the object naming though, it matched more with the front end naming, so it was easy to connect the dots. That’s mostly where I struggle in the C4D docs, and confusion sets in fast for me. Like BaseContainer, Atom, Description, etc... I see the App > Object Panel > Object > Parameter > Value (as a very basic example)
Granted I never took a traditional route for learning coding, and am self taught.
Thanks again for the tips you keep mentioning. I really appreciate it.
Hi sorry to come late to the party, so to answers your initial questions:
So I took another way to extract what changed and what not changed, by simply creating a new object and check the changed value. This also supports tag additions.
import c4d class Parameter(object): # Represent a parameter def __init__(self, paramIdent, paramName, paramValue): self.paramIdent = paramIdent self.paramName = paramName self.paramValue = paramValue def __str__(self): return '"{1}", c4d.{0} {2}'.format(self.paramIdent, self.paramName, self.paramValue) def __repr__(self): return str(self) def GetChangedParameter(bl2D): # Retrieve the changed parameter, by creating the BaseList2D and comparing the description and value # Create an object with default value cls = bl2D.__class__ blTypeId = bl2D.GetType() newBl2D = cls(blTypeId) newBl2D.Message(c4d.MSG_MENUPREPARE, None) changedParams = [] # Will contains all the changed Parameter unwantedIds = [c4d.ID_BASELIST_ICON_COLOR, c4d.ID_MG_MOTIONGENERATOR_EFFECTORLIST] # List of excluded parameter because they are always different # Iterate teh description of the existing obj description = bl2D.GetDescription(c4d.DESCFLAGS_DESC_0) for bc, paramId, groupId in description: # if we dont want to deal with this parameter continue the loop if paramId[0].id in unwantedIds: continue # Ignore group if paramId[0].dtype == c4d.DTYPE_GROUP: continue # If a parameter is not within the newly created, something went wrong if not description.CheckDescID(paramId, [newBl2D]): raise ValueError("{0} not found in the created instance".format(paramId)) # Try excecute, because some Datatype are not present in Python # here we retrieve the value of the parameter in the scene Bl2D and the newly created try: bl2DValue = bl2D[paramId] newBl2DValue = newBl2D[paramId] # If they are not equal, append a new parameter in the changedParams list if bl2DValue != newBl2DValue: newParam = Parameter(bc[c4d.DESC_IDENT], bc[c4d.DESC_NAME], bl2DValue) changedParams.append(newParam) except: pass return changedParams def HierarchyIterator(bl2D): """ A Generator to iterate over the Hierarchy :param bl2D: The starting object of the generator (will be the first result) :return: All objects under and next of the `bl2D`, so any BaseList2D """ while bl2D: yield bl2D for opChild in HierarchyIterator(bl2D.GetDown()): yield opChild bl2D = bl2D.GetNext() def GetAddedTags(obj, excludedTags): # Retrieve added tags by creating the object and look which tags are added or not if not isinstance(obj, c4d.BaseObject): return # Create a new obj objTypeId = obj.GetType() newObj = c4d.BaseObject(objTypeId) # Function which return a dict with key as Tag Type and entry are a list of tags, {tagType: [c4d.BaseTag]} def _GetTags(obj, excludedTags): tags = {} for tag in obj.GetTags(): tagType = tag.GetType() if tagType in excludedTags: continue if tagType in tags: tags[tagType].append(tag) else: tags[tagType] = [tag] return tags # Retrieve Tags information tags = _GetTags(obj, excludedTags) newTags = _GetTags(newObj, excludedTags) missingTags = [] # will be filled with missing tags for tagId in tags: # A tag type is not present in the new one add it if tagId not in newTags: for t in tags[tagId]: missingTags.append(t) continue # obj present in the scene have more tag than the defualt one if len(tags[tagId]) > len(newTags[tagId]): missingTags.extend(newTags[len(tags[tagId]):]) return missingTags # Main function def main(): ignoredObjs = [] ignoredTags = [c4d.Tphong] for obj in HierarchyIterator(doc.GetFirstObject()): if obj.GetType() in ignoredObjs: continue changedParams = GetChangedParameter(obj) addedTags = GetAddedTags(obj, ignoredTags) # Print obj Name if changedParams or addedTags: print(obj.GetName()) # Print obj changed parameter for param in changedParams: print("{0}{1}".format(" "*2, param)) # Print missing Tag for tag in addedTags: print("{0}Missing Tag: {1}".format(" "*2, tag.GetName())) # Print modified value for phong for param in GetChangedParameter(tag): print("{0}{1}".format(" "*4, param)) # Execute main() if __name__=='__main__': main()
Regarding the Python documentation, we are of course looking to improve it, so if you have any advice, please feel free to give us. Just a side note each class you can see the parent class and children classes, so you can quickly find all the methods of a class. Here an example for the BaseList2D class
@m_adam Wow, thanks Maxime for the explanation and code. I was not expecting that amount of effort.
I ran the code and encountered two errors so far. I believe one may be App version related possibly, and the other I am unsure.
So first the section in your GetChangedParameter function
# List of excluded parameter because they are always different unwantedIds = [c4d.ID_BASELIST_ICON_COLOR, c4d.ID_MG_MOTIONGENERATOR_EFFECTORLIST]
I get this attribute error
AttributeError: 'module' object has no attribute 'ID_BASELIST_ICON_COLOR'
I am assuming this may be an ID added after R20. I am still using R20 for context. Once I remove it from the list the rest of the code will execute.
The second error I get is when encountering any polygon object. For example you can throw down any primitive shape and make it editable to test this.
When a polygon object is encounter this type error is thrown:
TypeError: Required argument 'vcnt' (pos 2) not found
My guess is that since it's a polygon object (which could be a native primitive made editable or a custom geometry imported by user) C4D has no direct reference to recreate the object in a default state?
So far those are the only two issues I have come across.
Hello @davidtorno,
without any further questions or replies, we will consider this topic to be solved by Monday and flag it accordingly.
