I have a Maxon::Url, containing the following: file:///Applications/Maxon/Cinema 4D R22/plugins/myplugin/help/content/omyobject/omyobject.html#MYOBJECT_ATTRIBUTE.
The Url was assembled in a PluginHelpDelegate:
maxon::Url url; url.SetUrl(GeGetPluginPath().GetString(), true) iferr_return; url.Append("help"_s) iferr_return; url.Append("content"_s) iferr_return; url.Append(baseType.ToLower()) iferr_return; url.Append(opType.ToLower() + ".html#"_s + property) iferr_return;
The Url is correct, if I copy & paste it into Safari or Chrome, the page opens as expected.
But trying to open it from within Cinema 4D, using GeOpenHTML(url.GetUrl()); just returns false. Why?
false
Cheers, Frank
Ah, I made it work like this:
maxon::String urlStr = url.GetUrl(); urlStr.Replace(" "_s, "%20"_s) iferr_return; ... GeOpenHTML(urlStr);
But this replacement seems clumsy. Isn't there a function in the API to escape URLs?
hi,
the only way i found was using the old FilenameToURL witch is a static function that need a Filename and return a string.
static maxon::Tuple<maxon::String, Int32> EscapeUrl(maxon::Url& url) { Filename urlToEscape = MaxonConvert(url); Int32 encoding; maxon::String myUrlAsEscapedString = HtmlViewerCustomGui::FilenameToURL(urlToEscape, &encoding); return { myUrlAsEscapedString, encoding }; } static maxon::Result<void> pc12829_action(BaseDocument* doc) { iferr_scope; maxon::Url myUrl {"file:////Applications/Maxon/Cinema 4D R2/plugins/myplugin/help/content/omyobject/omyobject.html#MY OBJCT_ATTRIBU TE"_s }; maxon::Tuple<maxon::String, Int32> convertedResult = EscapeUrl(myUrl); maxon::String myUrlAsEscapedString = convertedResult.GetFirst(); Int32 encoding = convertedResult.GetSecond(); ApplicationOutput("the url is @ and escaped is @ the url was escaped is @", myUrl, myUrlAsEscapedString, encoding == URL_ENCODING_ESCAPED); return maxon::OK; }
But your # will be transform to %23 so you have to be careful with that. But property is something that you can control and shouldn't have space there.
%23
Cheers, Manuel
Why not use IoShowInOS()? (didn't test it on macOS though).
IoShowInOS()
maxon::Url url { "file:///D:/_tests/test.html"_s }; url.IoShowInOS(maxon::IOSHOWINOSFLAGS::OPEN_IN_EXPLORER) iferr_ignore("");
See Url Manual.
@PluginStudent said in How do I open a maxon::Url in the default web browser?:
Why not use IoShowInOS()? (didn't test it on macOS though). maxon::Url url { "file:///D:/_tests/test.html"_s }; url.IoShowInOS(maxon::IOSHOWINOSFLAGS::OPEN_IN_EXPLORER) iferr_ignore(""); See Url Manual.
I was so focused on escaping the URL, thanks a lot @PluginStudent
Oh, cool! I'll test that. Thank you!
Hmmmm, well, on the one hand this function is a nice thing: It really does do the escaping for me, so the spaces in the URL are correctly replaced with "%20".
But it does not handle anchors in a URL.
This URL works fine: file:///Applications/Maxon/Cinema 4D R22/plugins/myplugin/help/content/omyobject/omyobject.html
But this URL is not opened, instead an error (code -43) is thrown: file:///Applications/Maxon/Cinema 4D R22/plugins/myplugin/help/content/omyobject/omyobject.html#MYOBJECT_ATTRIBUTE
That is a pity.
