Hey guys, i have a script which uses the c4d.utils.SendModelingCommand until recently this returned a list to me. https://developers.MAXON.net/docs/Cinema4DPythonSDK/html/modules/c4d.utils/index.html#c4d.utils.SendModelingCommand
This function either returns a boolean, or a list. Up until R21 the following code returned a list to me. But as of S22 i get returned the bool true, which signifies it ran succesfully, but i cant seem to retrieve the list.
Any help on how i can get the list ( by passing a parameter or anything else ) would be appreciated.
Heres the related snippet of my code
selId = [] sel = op.GetPolygonS() for index, selected in enumerate(sel.GetAll(polyCnt)): if not selected: continue selId.append(index) allPolys = [n for n in allPolys if n not in selId] settings = c4d.BaseContainer() res = utils.SendModelingCommand(command = c4d.MCOMMAND_SPLIT, list = [op], mode = c4d.MODELINGCOMMANDMODE_POLYGONSELECTION, bc = settings, doc = doc)
after running this script, res is now true instead of a List
many thanks in advance.
Thanks for the complete code, the issue is not located in the MCOMMAND_SPLIT but in the ID_MODELING_FILL_SELECTION_TOOL, within the S22 development cycle, parameters IDs changed but the new ones were not exposed to Python (I've created a bug report) so you need to hardcode them, like so
startPolyID = c4d.MDATA_FILLSEL_START_POLY if c4d.GetC4DVersion() < 21600 else 1100 # MDATA_FILL_POLYGON_INDEX in C++ selectionTypeID = c4d.MDATA_FILLSEL_SELECTION if c4d.GetC4DVersion() < 21600 else 1110 # MDATA_FILL_SELECTION_TYPE in C++
And here your code adapted to work
import c4d from c4d import gui,utils def main(): if op.GetType() != c4d.Opolygon : return sel = op.GetPolygonS() polyCnt = op.GetPolygonCount() allPolys = range(polyCnt) doc.StartUndo() null = c4d.BaseObject(c4d.Onull) null[c4d.ID_BASELIST_NAME] = op[c4d.ID_BASELIST_NAME]+"_Segments" null.SetMg(op.GetMg()) cntr = 0 while allPolys: settings = c4d.BaseContainer() startPolyID = c4d.MDATA_FILLSEL_START_POLY if c4d.GetC4DVersion() < 21600 else 1100 # MDATA_FILL_POLYGON_INDEX in C++ selectionTypeID = c4d.MDATA_FILLSEL_SELECTION if c4d.GetC4DVersion() < 21600 else 1110 # MDATA_FILL_SELECTION_TYPE in C++ settings[startPolyID] = allPolys[0] settings[selectionTypeID] = c4d.SELECTION_NEW # Or SELECTION_ADD or SELECTION_SUB utils.SendModelingCommand(command = c4d.ID_MODELING_FILL_SELECTION_TOOL, list = [op], mode = c4d.MODELINGCOMMANDMODE_EDGESELECTION, bc = settings, doc = doc) selId = [] sel = op.GetPolygonS() for index, selected in enumerate(sel.GetAll(polyCnt)): if not selected: continue selId.append(index) allPolys = [n for n in allPolys if n not in selId] settings = c4d.BaseContainer() res = utils.SendModelingCommand(command = c4d.MCOMMAND_SPLIT, list = [op], mode = c4d.MODELINGCOMMANDMODE_POLYGONSELECTION, bc = settings, doc = doc) res[0][c4d.ID_BASELIST_NAME] = op[c4d.ID_BASELIST_NAME] res[0].InsertUnderLast(null) res[0].SetMg(op.GetMg()) sel.DeselectAll() cntr += 1 doc.InsertObject(null) doc.AddUndo(c4d.UNDOTYPE_NEW, null) doc.EndUndo() c4d.EventAdd() if __name__=='__main__': main()
Cheers, Maxime.
Hi @Awesuus first of all welcome in the plugincafe community
Unfortunately, I wasn't able to reproduce your result in S22 and we correctly had a list returned. So what's your exact Cinema 4D Version? ( I tested on S22.118). Could you upload the Cinema 4D file where you are experiencing this issue?
Thanks in advance, Cheers, Maxime.
Hi Maxime, Thank you so much for your reply. I also work in S22.118.
Here's the whole script that I'm trying to get to work:
import c4d from c4d import gui,utils def main(): if op.GetType() != c4d.Opolygon : return sel = op.GetPolygonS() polyCnt = op.GetPolygonCount() allPolys = range(polyCnt) doc.StartUndo() null = c4d.BaseObject(c4d.Onull) null[c4d.ID_BASELIST_NAME] = op[c4d.ID_BASELIST_NAME]+"_Segments" null.SetMg(op.GetMg()) cntr = 0 while allPolys: settings = c4d.BaseContainer() settings[c4d.MDATA_FILLSEL_START_POLY] = allPolys[0] utils.SendModelingCommand(command = c4d.ID_MODELING_FILL_SELECTION_TOOL, list = [op], mode = c4d.MODELINGCOMMANDMODE_EDGESELECTION, bc = settings, doc = doc) selId = [] sel = op.GetPolygonS() for index, selected in enumerate(sel.GetAll(polyCnt)): if not selected: continue selId.append(index) allPolys = [n for n in allPolys if n not in selId] settings = c4d.BaseContainer() res = utils.SendModelingCommand(command = c4d.MCOMMAND_SPLIT, list = [op], mode = c4d.MODELINGCOMMANDMODE_POLYGONSELECTION, bc = settings, doc = doc) res[0][c4d.ID_BASELIST_NAME] = op[c4d.ID_BASELIST_NAME] res[0].InsertUnderLast(null) res[0].SetMg(op.GetMg()) sel.DeselectAll() cntr += 1 doc.InsertObject(null) doc.AddUndo(c4d.UNDOTYPE_NEW, null) doc.EndUndo() c4d.EventAdd() if __name__=='__main__': main()
What I'm trying to get it to do is explode the mesh by edge selection, so that it creates a new null with the separate objects. The c4d file below is just a scene with a sphere with edge selections.
test.c4d
Thank you so much, this works like a charm!!!
