Hi! Does anyone know the proper technique for controlling the tessellation of a SplineObject in a python generator? I'm dynamically creating a spline of type c4d.SPLINETYPE_BSPLINE and when I drop it into the scene it is tessellating into a rather coarse polyline and I can't find the controls to smooth it out. I have tried creating a SplineHelp and using that to sample the spline at regular intervals, but it appears to only sample the same coarse tessellated spline, not the underlying bspline. I'm sure this is something simple that I'm overlooking! Many thanks!
Doesn't look coarse to me, neither as script nor as generator
Generator:
import c4d def main(): obj = c4d.SplineObject(4, c4d.SPLINETYPE_BSPLINE) p1 = c4d.Vector(0.0, 0.0, 0.0) p2 = c4d.Vector(100.0, 0.0, 0.0) p3 = c4d.Vector(100.0, 100.0, 0.0) p4 = c4d.Vector(0.0, 100.0, 0.0) obj.SetAllPoints([p1, p2, p3, p4]) obj[c4d.SPLINEOBJECT_INTERPOLATION] = 2 # here: uniform obj[c4d.SPLINEOBJECT_SUB] = 20 # number of subdiv points obj.Message (c4d.MSG_UPDATE) return obj
Did you use enough points? set the interpolation and subdivision? There is not much room for settings here...
Note that a Python generator cannot act as spline itself (see some other threads for that), even if it can contain a spline. There is currently no Python Spline Generator in C4D.
hi,
i was kind of lost this morning (i was warming up) because in our python documentation there's no real page that let you understand that you have to use SPLINEOBJECT_SUB
SPLINEOBJECT_SUB
just to add something you can generate null along the spline. You can use UniformToNatural.
import c4d def main(): obj = c4d.SplineObject(4, c4d.SPLINETYPE_BSPLINE) p1 = c4d.Vector(0.0, 0.0, 0.0) p2 = c4d.Vector(100.0, 0.0, 0.0) p3 = c4d.Vector(100.0, 100.0, 0.0) p4 = c4d.Vector(0.0, 100.0, 0.0) obj.SetAllPoints([p1, p2, p3, p4]) obj[c4d.SPLINEOBJECT_INTERPOLATION] = 2 # here: uniform obj[c4d.SPLINEOBJECT_SUB] = 20 # number of subdiv points obj.Message (c4d.MSG_UPDATE) parent = c4d.BaseObject(c4d.Onull) obj.InsertUnder(parent) # Creates null objects along the spline cnt = 50 sld = c4d.utils.SplineLengthData() sld.Init(obj, 0) for i in range(cnt + 1): null = c4d.BaseObject(c4d.Onull) null[c4d.NULLOBJECT_DISPLAY] = 1 pos = obj.GetSplinePoint( sld.UniformToNatural(i / float(cnt))) null.SetRelPos(pos) null.InsertUnder(parent) return parent
Cheers, Manuel
Thanks guys! This is exactly what I was looking for. I couldn't find any reference to the interpolation and sub settings but this solved it! I am curious what you mean Cairyn about a python generator not being able to create a spline. I use python generators for this purpose all the time, so I'm not sure I follow. Anything specific I should watch out for in the future?
@android Here's a thread for reference regarding the limitation of a Generator spline: https://plugincafe.maxon.net/topic/12596/is-it-possible-to-get-a-spline-wrap-object-to-use-a-python-generated-spline
