Toggle bitmap button on .res file
Is it possible to create a toggle bitmap button using only the
.res
file?
I tried with theGetDDescription
function its work well, but when I use.res
file this doesn't work.
Also, when I use theFORCE_SIZE
on.res
file I get an error.BITMAPBUTTON BUTTON_ID { TOGGLE; BUTTON; FORCE_SIZE 16; ICONID1 5160; ICONID2 5159; }
Thanks
hi,
something like this will work as you expect (i hope)
The trick is to create a two columns group and a dummy statictext so the button will have the "right" size.GROUP { COLUMNS 2; BITMAPBUTTON BUTTON_ID { SIZE 32; TOGGLE; BUTTON; ICONID1 5160; ICONID2 5159; } STATICTEXT { DUMMY; } }
One side effect is the icon will not be centered. You can see on this thread why.
Manuel
hi @m_magalhaes,
Thank you much, that works.
I have an another question concerning
Description Resource
, I don't know if I post it here or I must create a new post.Here is the code:
GROUP { REAL MYOBJECT_PITCH { UNIT DEGREE; CUSTOMGUI REALSLIDER; MIN -360; MAX 360; STEP 1; } BITMAPBUTTON MYOBJECT_STRAIGHTEST_PITCH { SIZE 16; BUTTON; ALIGN_LEFT; ICONID1 5160; } REAL MYOBJECT_ROTATION { UNIT DEGREE; CUSTOMGUI REALSLIDER; MINSLIDER -90; MAXSLIDER 270; STEP 1; } STATICTEXT { JOINENDSCALE; } }
And here screenshot of what I want to do:
Thanks
hi,
Group is the key in UI. Simply add a
SCALE_H;
property for your slider. so for that two columns group, the slider will take all the place minus the button.GROUP { COLUMNS 2; REAL ONEFLOAT { CUSTOMGUI REALSLIDER; SCALE_H;} BITMAPBUTTON BUTTON_ID { SIZE 16; TOGGLE; BUTTON; ICONID1 5160; ICONID2 5159; } }
Manuel
