Hi, bit of a newb question. When changing a setting on an object this used to work:
obj[c4d.MG_LINEAR_OBJECT_POSITION,c4d.VECTOR_Y] = 0.0
But now it doesn't, it keeps getting an unexpected type error even though the type should be a float. I read the sdk saying to use the "original set method" to avoid type errors but I'm not sure what the original method would be?
Hi @Motion4D you need to properly change parameters to have access to these parameters (as you will do via the user interface)
cloner = c4d.BaseObject(1018544) cloner[c4d.ID_MG_MOTIONGENERATOR_MODE] = c4d.ID_MG_MOTIONGENERATOR_MODE_LINEAR cloner[c4d.MGCLONER_FIX_CLONES] = False cloner[c4d.MG_LINEAR_OBJECT_POSITION, c4d.VECTOR_Y] = 0.0
Cheers, Maxime.
@m_adam said in Changing parameters broken in S22:
Thanks! @m_adam it worked but I'm just curious why we needed to specify the fixed clone mode to False?
Hi sorry, you are right, internally MGCONER_FIX_CLONES will force an update of the cloner position, forcing the generation of the description.
But doing
cloner = c4d.BaseObject(1018544) cloner[c4d.ID_MG_MOTIONGENERATOR_MODE] = c4d.ID_MG_MOTIONGENERATOR_MODE_LINEAR cloner.Message(c4d.MSG_CHANGE) cloner[c4d.MG_LINEAR_OBJECT_POSITION, c4d.VECTOR_Y] = 0.0 doc.InsertObject(cloner) c4d.EventAdd()
Is enough.
@m_adam Thanks for clarifying!
