Mute Object Animation
Is there a way to mute object animation using python?
Here's how to do it manually through the timeline editor:
https://www.dropbox.com/s/mact0ls02mq7mh4/c4d277_mute_object_animation_python.mp4?dl=0Regards,
Ben
Hi @bentraje this is the parameter
ID_CTRACK_ANIMOFF
.So here ho to disable the first track of an animated object.
track = op.GetFirstCTrack() track[c4d.ID_CTRACK_ANIMOFF] = False c4d.EventAdd()
Thanks for your response. Works as expected.
for track in op.GetCTracks(): # Just to get all tracks at once. track[c4d.ID_CTRACK_ANIMOFF] = 0 c4d.EventAdd()
@bentraje said in Mute Object Animation:
one could consider this nitpicky, but you should be careful with
GeListNode.__setitem__
and your input types. Here it probably will not matter, butID_CTRACK_ANIMOFF
is a boolean parameter and you rely on the fact thatGeListNode.__setitem__
is interpreting the passed integer literal as the correct boolean literal. If one is not using the specific function on the data container, i.e.SetBool
, I would always make sure to be as precise as possible with my data types, having all the oopsies in mind that can happen with filename and string parameters in containers and mixing them up.Cheers,
zipit
@zipit
Gotcha. Thanks for the reminder :)
