Best coding practices
I'm cleaning my code and I have some of questions about the best practices to prevent any cinema 4d app crash.
1 - Is it necessary to check if the object or tag it was created before inserting into the document?
Example:
obj = c4d.BaseTag(c4d.Onull) tag = c4d.BaseTag(c4d.Tdisplay) if not obj or not tag: return obj .InsertTag(tag)
2- Is there a specific case to use the condition
if value is None
orif obj_or_tag is None
instead ofif not value
orif not obj_or_tag
I've always used the
if not value
method.Thanks
no, it is not necessary in a strict sense of the word. The instantiation of a
BaseList2D
(i.e. a tag, an object, a shader, etc.) can fail when your computer runs out of memory. In that case the symbol of the node will referenceNone
. You handling this case or not only makes a difference in with what error message your program will stop (this hold true for all exception handling). But it is easier to debug code if you get a message that specially gives you a reason why the program did stop, rather than your code failing because an object (in the pythonic sense) is not what the code assumes it to be (e.g. Python would raise something likeAttributeError: NoneType has no attribute InsertTag
when the node instantiation did fail).The practice to state something like
if something is None: return
makes sense if you design a function which specifically includes returningNone
in its signature. But it is often also used like shown here in your code, to irregularly stop a program when something is going wrong. While this usage is not specifically wrong, most style guides advise against it, because it makes it hard to understand why the program did stop and also that it did stop irregularly in the first place. Use exceptions and be verbose instead. So for your code this would be something like.if obj is None: raise MemoryError("Could not instantiate object.")
Finally, if you say
if not obj:
orif obj is None:
makes no real difference in this case (the literalNone
will evaluate asFalse
and a node instance will evaluate asTrue
). However, the first one is sometimes is considered to be bad style, because it lacks the verbosity and makes the code harder to read. It also might proof treacherous if you are not aware of the truth testing behaviour of the the Python object you are testing - for integer literals the value0
evaluates asFalse
for example.Cheers,
zipit
BaseList2D
Finally, if you say
if not obj:
orif obj is None:
evaluates asFalse
for example.Cheers,
zipit
@zipit Thank you much.
