Hi all, I tried the code described in this thread: https://plugincafe.maxon.net/topic/6626/7199_r14-snap-system/10 This code inside the liquitool example work as expected. But if i try to use SnapCore::Intersect instead SnapCore::Snap, to get the normal at point, this code don't work.
This is the line that I changed to: if (snap->Intersect(pos, norm, false, res)) instead if (snap->Snap(pos, res))
Seem that the intersection don't work anymore.
Any help? Thanks in advance Renato T.
Real mx = msg.GetReal(BFM_INPUT_X); Real my = msg.GetReal(BFM_INPUT_Y); LONG button; switch (msg.GetLong(BFM_INPUT_CHANNEL)) { case BFM_INPUT_MOUSELEFT : button=KEY_MLEFT; break; case BFM_INPUT_MOUSERIGHT: button=KEY_MRIGHT; break; default: return TRUE; } AutoAlloc<SnapCore> snap; // Allocate snap if (!snap) return FALSE; snap->Init(doc, bd); Real dx, dy; BaseContainer bc; BaseContainer device; Vector pos; SnapResult res; BaseObject *active = doc->GetActiveObject(); win->MouseDragStart(button, mx, my, MOUSEDRAGFLAGS_DONTHIDEMOUSE|MOUSEDRAGFLAGS_NOMOVE); while (win->MouseDrag(&dx,&dy,&device)==MOUSEDRAGRESULT_CONTINUE) // Start drag { // Increment mouse position during drag mx += dx; my += dy; pos = bd->SW(Vector(mx, my, 500)); // Update pos if (snap->Snap(pos, res)) // If point snap anywhere { pos += res.delta; // Pos will be updated with snapped delta } if (active) active->SetAbsPos(pos); // Set the object position to the new one! DrawViews(DRAWFLAGS_ONLY_ACTIVE_VIEW|DRAWFLAGS_NO_THREAD|DRAWFLAGS_NO_ANIMATION); // Update viewport } win->MouseDragEnd(); // Reset viewport status EventAdd();
Seem that the normal is returned by SnapCore::Snap in SnapResult::mat.v2. I'm verifying
Hi @RenatoT, I don't think there is an issue,
just in case Intersect is supposed to work only for guide and spline see Modeling Settings - Intersection Snap. So maybe you are looking for GeRayCollider::Interesct.
Cheers, Maxime.
Hi Maxime. Thanks for reply. At last I used the BVHTree for that.
