Check if the object parameters has been changed
The following line of code is supposed returning True only if parameters of the object changed? But why it also returning True when my object selected and I Move / Scale / Zoom / rotate the perspective view.
# dirty = True if a cache is dirty or if the data (any parameters) of the object changed. dirty = op.CheckCache(hh) or op.IsDirty(c4d.DIRTY_DATA)
Thanks.
Hi @mfersaoui thanks for writing us.
That's partially true: the expression can be
True
also if the object's cache is dirtyBut why it also returning True when my object selected and I Move / Scale / Zoom / rotate the perspective view.
That's weird and to answer here you've to show how you're using it with the rest of your ObjectData::GetVirtualObjects() method.
Best, R
I am a bit confused about @r_gigante answer, I might be misunderstanding something here.
BaseObject.GetCache
will return the hierarchical cache tree for an object orNone
if neither the object nor its cache children has a cache.Since objects (in a pythonic sense) do evaluate as
True
, your expression will evaluate in 99% of the cases asTrue
. The natural language version of the expression would be: Has the object been touched or has itself or one of its cache children a cache? You are probably missing anot
/ negation in your expression.Cheers,
zipit
@zipit: I'm a bit confused of your remarks here as well
In my answer I see no reference toBaseObject::GetCache()
here and looking at the documentation of both methods reported in the initial boolean expression, to answer first @mfersaoui's question, it results to beTrue
if the cache is dirty or any object's parameter has become dirty.Cheers, R
jeah, my bad, happens when you write stuff on the train. I was mixing up
BaseObject.CheckCache
withGetCache
.Cheers,
zipit
Hi, Thank you @r_gigante, @zipit for your replies.
The problem comes from the GetDDescription funtion because I use some of dynamic parameters on my objects.
It is for this reason thatop.IsDirty(c4d.DIRTY_DATA)
returning True when I Move, Scale, Zoom or Rotate the perspective view.
