PointInRange details please
Hi
About thePointInRange
the documentation mentions:Checks if the screen point (x,y) is within a hit range of the world point p, i.e. if the screen point is close to the world points projection on the screen.
It does not provide details about what the actual "range" represents. Nor does it indicate if (and how) this range can be controlled/adjusted.
Is the current LiveSelection radius value used for this "range", something else, internally defined, ... ?
Thanks in advance for the details.Edit:
Allright, I can already confirm it is not the LiveSelection's radius ...
hi,
seem to be hardcoded to
SELECT_RANGE
Vector p = WS(po); p.z = 0.0; p.x -= (Float)x; p.y -= (Float)y; return p.GetSquaredLength() <= SELECT_RANGE * SELECT_RANGE;
#define SELECT_RANGE 10 // Range Radius
But as you can see, this is pretty easy to create your own function, there's nothing fancy
Manuel
@m_magalhaes said in PointInRange details please:
True, and I did.
I just wanted to bring this up, as the documentation was rather ambiguous.
