I have the following code which was able to get the path but can't update the path
flags = c4d.SCENEFILTER_MERGESCENE | c4d.SCENEFILTER_OBJECTS | c4d.SCENEFILTER_MATERIALS active_doc = c4d.documents.GetActiveDocument() merge_status = c4d.documents.MergeDocument(active_doc, target_scene, flags) assert(merge_status) # Model[c4d.ID_CA_XREF_FILE] obj_name_to_search = 'Model' xref = active_doc.SearchObject(obj_name_to_search) alembic_path = xref.GetParameter(c4d.ID_CA_XREF_FILE, c4d.DESCFLAGS_GET_NONE) print(alembic_path) status = xref.SetParameter(c4d.ID_CA_XREF_FILE, animated_alembic_file, c4d.DESCFLAGS_SET_PARAM_SET) assert(status) if True: c4d.documents.SaveDocument(active_doc, target_scene, c4d.SAVEDOCUMENTFLAGS_0, c4d.FORMAT_C4DEXPORT)
Hi @nicholas_yue , thanks for reaching out us.
With regard to your question please be aware that C4DAtom::SetParameter() has to be called with DESCFLAGS_SET_USERINTERACTION flag to set ID_CA_XREF_FILE.
ID_CA_XREF_FILE
Best, Riccardo
@r_gigante said in Unable to update Alembic path in xref:
Using DESCFLAGS_SET_USERINTERACTION there was a prompt in my script.
Update XRef (Yes) or replace (No)?
How do I respond (Yes) in my script ?
Unfortunately, there is no built-in way to control MessageBox within Cinema4D.
The only way for you is to install a 3rd party python package, here a possible one https://github.com/asweigart/pyautogui.
Cheers, Maxime.
@m_adam said in Unable to update Alembic path in xref:
Unfortunately, there is no built-in way to control MessageBox within Cinema4D. The only way for you is to install a 3rd party python package, here a possible one https://github.com/asweigart/pyautogui. Cheers, Maxime.
But I am running the script with c4dpy, there is no UI.
Is there something I can call in c4dpy to tell the current active session to default to "Yes", it seems that c4dpy defaults to "No"
I know, it's not what you expected but there is for the moment no way to automate this using Cinema 4D API.
