Change parameter's unit type
Hi everyone,
Trying to create a functionality, when parameter's unit would be changed based on selected mode - either real unit, either percentage.
I'm pretty sure it has to be handled within the GetDDescription method, but I can't find related example or doc.Here's what I need, I have integer parameter TESTPLUGIN_MODE, which might be one of the TESTPLUGIN_DISTANCE or TESTPLUGIN_PERCENTAGE values.
And I have float offset parameter TESTPLUGIN_OFFSETSo if TESTPLUGIN_MODE equals to TESTPLUGIN_DISTANCE, then TESTPLUGIN_OFFSET unit should be METER
else unit should be PERCENT;Below is my res file "testplugin.res":
CONTAINER Otestplugin { NAME Otestplugin; INCLUDE Obase; GROUP ID_OBJECTPROPERTIES { DEFAULT 1; GROUP { LONG TESTPLUGIN_MODE { CYCLE { TESTPLUGIN_DISTANCE; TESTPLUGIN_PERCENTAGE; }; DEFAULT TESTPLUGIN_DISTANCE; } REAL TESTPLUGIN_OFFSET { CUSTOMGUI LONGSLIDER; MINSLIDER -1000; MAXSLIDER 1000; DEFAULT 0; } } } }
And Otestplugin.pyp part (actually nothing):
def GetDDescription(self, node, description, flags): if not description.LoadDescription(node.GetType()): return False data = node.GetDataInstance() return (True, flags | c4d.DESCFLAGS_DESC_LOADED)
Parameter units are defined with the
c4d.DESC_UNIT
property. See Description Settings Manual.To change the properties of an existing parameter, one would have to translate this code to Python: Description Manual.
c4d.DESC_UNIT
in case you struggle, here is an example for Python, which hides stuff based on based on some booleans. There is also a Python specific resource for that what @PluginStudent already linked you. You can find it here.
zipitdef GetDDescription(self, node, description, flags): """Show and hide parameters based on the sampling type. Args: node (c4d.GeListNode): An instance of a TopologyMap tag. description (c4d.Description): The description of the tag. flags (int): The flags for the description operation. Returns: bool or tuple(bool, int): Success of the description modification. """ if (not description or not node or not description.LoadDescription(node.GetType())): return False # Here I am polling the passed description for a specific attribute. bc = description.GetParameterI(c4d.DescID( c4d.DescLevel(c4d.IDC_CURVATURE_FOLD))) if bc: # Here I am just polling the node, i.e. the tag in this case, for # an attribute based on which we want to do something. state = node[c4d.IDC_SAMPLING_TYPE] != c4d.IDV_TYPE_CURVATURE # And here I modify the description, see c4d.Description for details. bc.SetBool(c4d.DESC_HIDE, state) # And the rest is just the same stuff, but for other attributes. # Orientation bc = description.GetParameterI(c4d.DescID( c4d.DescLevel(c4d.IDC_ORIENTATION_OPTIONS))) if bc: state = node[c4d.IDC_SAMPLING_TYPE] != c4d.IDV_TYPE_ORIENTATION bc.SetBool(c4d.DESC_HIDE, state) # Thickness bc = description.GetParameterI(c4d.DescID( c4d.DescLevel(c4d.IDC_THICKNESS_SAMPLES))) if bc: state = node[c4d.IDC_SAMPLING_TYPE] != c4d.IDV_TYPE_THICKNESS bc.SetBool(c4d.DESC_HIDE, state) return (True, flags | c4d.DESCFLAGS_DESC_LOADED)
@PluginStudent thanks
@zipit thanks a lot, but based on c++ docs made this (seems there are just more checking):
def GetDDescription(self, node, description, flags) : data = node.GetDataInstance() if data is None or not description.LoadDescription(node.GetType()): return False singleID = description.GetSingleDescID() paramID = c4d.DescID(c4d.DescLevel(c4d.TESTPLUGIN_OFFSET)) if ( singleID is None or paramID.IsPartOf(singleID)[0] ): bc = description.GetParameterI(paramID) if (bc): if data.GetLong(c4d.TESTPLUGIN_MODE) == TESTPLUGIN_MODE_DISTANCE: bc.SetLong(c4d.DESC_UNIT, c4d.DESC_UNIT_METER) else: bc.SetLong(c4d.DESC_UNIT, c4d.DESC_UNIT_PERCENT) return (True, flags | c4d.DESCFLAGS_DESC_LOADED)
