Finding my Plug-in Tag
    On 03/06/2003 at 07:55, xxxxxxxx wrote:
    Cinema 4D Version:   8.100
    Platform:   Windows  ;
    I have build a tag plug-in and would like to retrieve its settings from objects to which I've attached it. My idea was to call
    pointerToSomeObject->GetTag(type)
    with "type" set to the ID number of my plug-in. But that doesn't find anything (result == NULL). Using the constant namend Tplugin as value of type doesn't work either. Any suggestions?
    Thanks in advance.
    Regards,
    Joern
    On 07/06/2003 at 09:27, xxxxxxxx wrote:
    my solution was plugintag=BaseObject->GetTag(
    Tplugin, nr
    ) and after that  plugintag->GetName. Then you can compare the tag name with your name.
    Hope it help and isn't too late
    Cathleen
    On 07/06/2003 at 13:08, xxxxxxxx wrote:
    Well, that seems a bit unsafe to me? The user might edit the name ...
    I guess how to find one's "own" objects is a very basic question not only concerning tags. I'll start a new thread. See you there ;-)
    Regards,
    Joern
