BaseDraw in TagDataPlugin
I'd like to draw a 2D line over the Viewport from a TagDataPlugin while the tag is Enabled. This is my Drawing function below. It worked as an ObjectData plugin when I called it withDRAWPASS_OBJECT
, but I'm not sure how to get this working as a Tag. Can anyone advise me on this? Thank you!class BaseDrawTest(c4d.plugins.TagData): def __init__(self, *args): super(BaseDrawTest, self).__init__(*args) def Draw(self, tag, op, bd, bh): bd.SetPen(c4d.Vector(1, 0.7, 0)) v1 = c4d.Vector(0.0,0.0,0.0) v2 = c4d.Vector(1000.0,1000.0,1000.0) bd.SetMatrix_Screen() bd.DrawLine2D(v1, v2)
Hi @blastframe, I'm not sure what is your issue, does the draw method is called? Because since S22 to get the Draw method called you needed to register your TagData with the
c4d.TAG_IMPLEMENTS_DRAW_FUNCTION
flags.Or does the Draw method is called but the result is not what you expected? If yes can you provide a screenshot of what you are aiming, or describe a bit more your issue?
@m_adam My apologies for not being clearer. I thought there was something wrong with how I was doing the Draw function. The issue was the
flag was missing.Thank you very much!
