How to bake shader into basebitmap?
Hi all,
I'm trying to use BaseShader::BakeShaderIntoBaseBitmap() to get a 2D representation of the shader. However, I couldn't get the correct result.
BaseDocument* bd = GetActiveDocument(); InitRenderStruct irs{ bd }; BaseBitmap* bit = BaseBitmap::Alloc(); BaseShader* shader = mat->GetChannel(CHANNEL_DIFFUSION)->GetShader(); shader->BakeShaderIntoBaseBitmap(*bit, *bd, irs.thread, false, irs.document_colorprofile, irs.linear_workflow, true, 0, 1000, 0, 1000) ShowBitmap(bit);
I have read 'BaseShader Manual', but I'm not sure where to get a parentThread, so I used irs.thread...
Any ideas or examples?
hi,
What do you mean by "get the correct result" ?
in the BaseShader manual, the thread is just the current thread :
BaseThread* const parentThread = GeGetCurrentThread(); if (parentThread == nullptr) return maxon::UnexpectedError(MAXON_SOURCE_LOCATION);
You should just have to passe the thread provided to you by a function argument where you are executing your code, retrieve the CurrentThread or use
nullptr
.Your bitmap must be initialise :
AutoAlloc<BaseBitmap> bitmap; if (bitmap == nullptr) return maxon::OutOfMemoryError(MAXON_SOURCE_LOCATION); const maxon::Int32 sizeX = 256; const maxon::Int32 sizeY = 256; const maxon::Int32 bitDepth = 32; const IMAGERESULT imageResult = bitmap->Init(sizeX, sizeY, bitDepth, INITBITMAPFLAGS::NONE); if (imageResult != IMAGERESULT::OK) return maxon::OutOfMemoryError(MAXON_SOURCE_LOCATION);
By the way, the bitmap argument pointer passed to BakeShaderIntoBaseBitmap should be passe without the * before it.
hope that help, let us know if you have more questions
Manuel
Thanks a lot!
