CCurve.GetValue() with Track Before & After Functions
I'm usingCCurve.GetValue()
, but it only seems to work when there is an actual curve, not when there is a Track Before or After Function. Is there a way to get the value of the attribute withCCurve.GetValue()
when using these functions?Thank you!
hi,
i create a simple example and it's working here. Just some precision issue (39.99999 instead of 40) but nothing too strange.
There's also this thread that could help you.
If you need to use the curve, you have to use the Remap function.import c4d from c4d import gui # Main function def main(): tracks = op.GetCTracks() fps = doc.GetFps() time = c4d.BaseTime(20, fps) for track in tracks: print track.GetValue(doc, time, fps) curve = track.GetCurve(c4d.CCURVE_CURVE) if curve: newTime = track.Remap(time.Get())['ret_time'] newTime = c4d.BaseTime(newTime) print curve.GetValue( newTime, fps) # Execute main() if __name__=='__main__': main()
Manuel
hi,
Manuel
@m_magalhaes
Remap
did the trick! Thanks for the help, Manuel
