Hi! In Javascript there's an event onfocusout triggered when the user has left an editable text input.
onfocusout
Similarly, I want to execute a function when the user leaves the EditText (by Tab or mouse) of my GeDialog. I thought maybe I could listen for the message with the ID of c4d.BFM_LOSTFOCUS, but that seems to be when the entire GeDialog loses focus (similar to c4d.BFM_ACTIVE_CHG). I also tried c4d.BFM_INTERACTEND but that happens after every input, including keystrokes. How can I listen for when a user leaves an EditText please? Thank you!
c4d.BFM_LOSTFOCUS
c4d.BFM_ACTIVE_CHG
c4d.BFM_INTERACTEND
ids = [c4d.BFM_MARKFOCUS,c4d.BFM_ACTIVE_CHG,c4d.BFM_SETFOCUS,c4d.BFM_INTERACTEND,\ c4d.BFM_ACTION,c4d.BFM_LOSTFOCUS] def Message(self, msg, result): if msg.GetId() in self.ids: for cid,val in msg: print cid,val return c4d.gui.GeDialog.Message(self, msg, result)
@blastframe
Maybe not the best solution, but I have tried the following code (C++) and it displays a text in the console when the Edit Text gets the focus, and displays another text when it loses focus.
Note that 'mActiveEdit' is a custom bool variable, member of MyDialog class, and ID_TEXTEDIT is the Edit Text gadget id.
Int32 MyDialog::Message(const BaseContainer& msg, BaseContainer& result) { if (IsActive(ID_TEXTEDIT) && !mActiveEdit) { ApplicationOutput("Activate TextEdit"); mActiveEdit = true; } if (!IsActive(ID_TEXTEDIT) && mActiveEdit) { ApplicationOutput("TextEdit was active"); mActiveEdit = false; }
@C4DS This solution works for me! Unless someone from the SDK team advises against for some reason, I'll mark yours as the correct answer. Here's a Python version of your code:
import c4d from c4d import gui PLUGIN_ID = 9999996 #Test ID class My_Dlg(gui.GeDialog): mActiveEdit1 = False mActiveEdit2 = False ID_TEXTEDIT1 = 1001 ID_TEXTEDIT2 = 1002 def CreateLayout(self): self.SetTitle("Edit Text Focus Events") if self.GroupBegin(1000, c4d.BFH_SCALEFIT | c4d.BFV_SCALE |\ c4d.BFV_CENTER, initw=0, inith=0, cols=1, rows=1, title=""): self.GroupBorderSpace(20, 20, 20, 20) #left, top, right, bottom self.AddEditText(self.ID_TEXTEDIT1, c4d.BFH_SCALEFIT, 90, 0) self.AddEditText(self.ID_TEXTEDIT2, c4d.BFH_SCALEFIT, 90, 0) self.GroupEnd() return True def ActivateEditText(self,id,active): activeBool = getattr(self,active) if self.IsActive(id) and not activeBool: print("Activate TextEdit: %s"%id) setattr(self,active,True) elif not self.IsActive(id) and activeBool: print("TextEdit %s was active"%id) setattr(self,active,False) def Message(self, msg, result): self.ActivateEditText(self.ID_TEXTEDIT1,"mActiveEdit1") self.ActivateEditText(self.ID_TEXTEDIT2,"mActiveEdit2") return c4d.gui.GeDialog.Message(self, msg, result) def Command(self, id, msg): return True def main(): global myDlg myDlg = My_Dlg() myDlg.Open(dlgtype=c4d.DLG_TYPE_ASYNC, xpos=-2, ypos=-2,\ pluginid=PLUGIN_ID, defaultw=300, defaulth=200) if __name__=='__main__': main()
Thanks again!
While the topic is set to solved.
I confirm there is no built-in way for doing what you are asking for. Maybe it would have more sense to create a Timer, instead of checking in Message (Since Message is called very very often so it may be more interesting to check only each second / 0.5 sec)
Cheers, Maxime.
@m_adam Great idea! I'll use a Timer Thanks Maxime!
