When I use this Script:
MoSelectionTag = mo.GeGetMoDataSelection(op) Count = MoSelectionTag.GetCount()
I can get the moSelection Tag (Tmgselection) Count. So far so good. But if I have more than 1 moSelection Tags, I need to iterate all tags, find the Tmgselection and get the Count for each one. Why doesn't this code work? How do I iterate through the tags and get the count of each Tmgselection? This code is in a Python Tag.
import c4d from c4d.modules import mograph as mo def main(): Cloner = op.GetObject() md = mo.GeGetMoData(Cloner) AllTags = Cloner.GetTags() for Tag in AllTags: if Tag.GetType() == c4d.Tmgselection: print Tag print Tag.GetCount()
it throws an Error: 'c4d.BaseTag' object has no attribute 'GetCount'
Replying to my own question. We need to define it using
mo.GeGetMoDataSelection(Tag)
Code that works.
import c4d from c4d.modules import mograph as mo def main(): Cloner = op.GetObject() md = mo.GeGetMoData(Cloner) AllTags = Cloner.GetTags() for Tag in AllTags: if Tag.GetType() == c4d.Tmgselection: print Tag SelTag = mo.GeGetMoDataSelection(Tag) #This is the new line print SelTag.GetCount()
