Make clean-up after script
Hello
I'm working with pyside2.
How to invoke clean-up methods in c4d enviroment?
For example, i made app and if close it or check visibilty,then del appfrom PySide2.QtWidgets import QApplication app = QApplication.instance() // steps with dialogs if win.isVisible() == False: del app
clean objects, any garbage collection in memory
to my knowledge, there is nothing special going on in this regard with Cinema's Python interpreter. Also note that invoking
del
does technically not enforce an object to be garbage collected even in the most of vanilla Python interpreters. It simply removes a reference to an object from the current scope. If the reference count for that object is then zero on the next collection cycle, it might be collected. Even if you have just one reference to an object and you remove that reference, it might still linger in memory for quite a while after that. Long story short: You cannot really enforce the deallocation of memory in Python.Cheers,
zipit
Hi @iluxa7k thanks for reaching out us.
With regard to your question, as already pointed out by @zipit , the Python
del
statement just is only responsible for decrementing the reference counter for the instance being "deleted" and not to actually free the memory used by the instance itself. This is clearly noted in the official Python documentation on the Note coming along withobject.__del__(self)
in Python 3 orobject.__del__(self)
in Python 2 .
Given that, also consider that thedel app
statement you've described in your first post might not actually deliver the "clean-up" action you're thinking about.Best, Riccardo
