On 01/06/2003 at 12:15, xxxxxxxx wrote:
User Information: Cinema 4D Version: 8.100 Platform: Windows ; Mac ; Mac OSX ; Language(s) : C++ ;
--------- Hello !
I have a plug that stores a baselink to an object. When the document is copied (when rendering in a window), does the link points to the copied object in the copied document or does it points to the original object in the original document?
Thanks for helping !
On 02/06/2003 at 01:25, xxxxxxxx wrote:
First of all, please resolve the conflicting SDK versions in your header/footer. I'm assuming you're using 8.100, since there are no BaseLinks in 6.3. When the document is copied the new base links point to the new document, since AliasTranslator::Translate() is called with connect_oldgoals set to TRUE.
