I have a custom data type for some time, and it works fine, without any GUI. I use it only to store data. Now I made a custom GUI, based on the DOTS example, and seems to work well. The GUI sets the data, I save the scene and when loaded it correctly displays the stored data.
But, when I try to access my custom data using GetParameter(), it's always empty. I rarely use the object's container to access data, took me some time to figure out the data was hidden there, but I don't understand why GetParameter() can't access it.
GetParameter()
To check if I was doing something wrong, I added a DOTS parameter to my object, and the same happens with it. The code below is inside a Generator's GetVirtualObjects(), we can clearly see the difference.
DOTS
GetVirtualObjects()
// With GetParameter() the dots array is always empty GeData dotsData; DescID desc( DescLevel( ID_USERDATA, DTYPE_SUBCONTAINER, 0 ), DescLevel( my_DOTS_parmeter, ID_SDK_EXAMPLE_CUSTOMDATATYPE_DOTS, 0 ) ); op->GetParameter( desc, dotsData, DESCFLAGS_GET_0 ); auto dots = static_cast<iCustomDataTypeDots*>( dotsData.GetCustomDataType( ID_SDK_EXAMPLE_CUSTOMDATATYPE_DOTS ) ); ApplicationOutput( "Dots GetParameter() size = " + String::IntToString( dots ? dots->_points.GetCount() : -1 ) ); // But the BaseContainer has it all... auto bc = op->GetDataInstance(); dots = static_cast<iCustomDataTypeDots*>( bc->GetData( my_DOTS_parmeter ).GetCustomDataType( ID_SDK_EXAMPLE_CUSTOMDATATYPE_DOTS ) ); ApplicationOutput( "Dots BaseContainer size = " + String::IntToString( dots ? dots->_points.GetCount() : -1 ) );
Is that a limitation? How do I make the data available from GetParameter()?
No idea why it does not work out of the box.
But you could implement NodeData::GetDParameter() to see if something weird happens there and to set the value yourself.
Edit: I just tested the scenario in R20 and with RoundedTube and everything seems to work fine.
RoundedTube
hi,
I confirm what @PluginStudent said. If you call GetParameter, it will end in the GetDParameter of the object if implemented or in NodeData::GetDParameter() witch by default do nothing and return true. That's why your always retrieve an empty data.
GetParameter
GetDParameter
Don't forget to initialise your data or to take that into account in the GetDParameter function
Cheers, Manuel
@m_magalhaes But GetParameter() does work for this custom type, when I'm not using a custom GUI. A LONG parameter with custom GUI also works with GetParameter(). Sounds like the combination Custom type + Custom GUI is missing something to have GetParameter() out of the box. But SPLINE for example, is both custom type and custom GUI, and I can access with GetParameter(). Ain't nothing missing on CustomGuiData, iCustomGui, CustomDataTypeClass or iCustomDataType to make it work?
LONG
SPLINE
CustomGuiData
iCustomGui
CustomDataTypeClass
iCustomDataType
I understand how I can make it work with GetDParameter(), but it feels unnecessary, any object that needs it will have that same pasted code.
GetDParameter()
after another look at it, the function will check the BaseContainer. If you Init the BaseContainer you don't even need the GetDParameter function.
BaseContainer
AutoAlloc<iCustomDataTypeDots> data; BaseContainer* bc = ((BaseList2D*)node)->GetDataInstance(); bc->SetData(5000, GeData(ID_SDK_EXAMPLE_CUSTOMDATATYPE_DOTS, data));
So yes, something is kind of missing, i need to figure this out. I need to dive to the code a bit. I didn't want to wait too much before giving you some feedback.
@m_magalhaes No hurry, for now there's just one place where I need this, I get it using the BaseContainer. But I will probably use it more often, so if the DOTS example is updated I can replicate the solution to my own type and remove this workaround.
Thanks!
