First Time calling SetAction does show the Brush tool's AM
Having some trouble understanding what's going on in following scenario.For testing purposes I have provided following implementation of two
CommandData
and oneDescriptionToolData
derived plugins. All are just dummy plugins for demonstration purposes only.
BothCommandData
plugins do activate theDescriptionToolData
from theirExecute
method. One does so by performing aCallCommand
, the other one by means ofSetAction
.- When you select the
CommandData
plugin which performs theSetAction
right after launching Cinema you then get the Brush tool's attributes in the Attribute Manager. - Restart Cinema and do the same with the one performing the
CallCommand
and you'll end up with the expected tool in the Attribute Manager.
If you now switch to another tool and then selects theSetAction
plugin you will also end up with the appropriate AM. - Restart Cinema, select a different tool (default scenes start with Move tool active, so select Live Selection), then select the
SetAction
plugin, and again the AM shows the expected tool.
So, why is it that when starting from a default launch (no actions performed yet) will show the Brush tool in the AM when performing a
SetAction
Is something missing in the registration of the tool plugin, or in the resource, or implementation of the tool? An if so, why is theCallCommand
not affected by this?I am including the description files only to show they're empty (for testing purposes).
#include "c4d.h" #define TEST_COMMAND1_PLUGIN_ID 1000001 #define TEST_COMMAND2_PLUGIN_ID 1000002 #define TEST_DESCRIPTIONTOOL_PLUGIN_ID 1000003 // ==================================== // CommandDatas // ==================================== // MyCommand1 - does perform a CallCommand to active the DescriptionTool class MyCommand1 : public CommandData { INSTANCEOF(MyCommand1, CommandData) public: virtual Bool Execute(BaseDocument* doc, GeDialog* parentManager); }; Bool MyCommand1::Execute(BaseDocument* doc, GeDialog* parentManager) { CallCommand(TEST_DESCRIPTIONTOOL_PLUGIN_ID); return true; } // MyCommand2 - does perform a SetAction to active the DescriptionTool class MyCommand2 : public CommandData { INSTANCEOF(MyCommand2, CommandData) public: virtual Bool Execute(BaseDocument* doc, GeDialog* parentManager); }; Bool MyCommand2::Execute(BaseDocument* doc, GeDialog* parentManager) { doc->SetAction(TEST_DESCRIPTIONTOOL_PLUGIN_ID); return true; } // ==================================== // DescriptionTool // ==================================== class MyDescriptionTool : public DescriptionToolData { public: virtual Int32 GetToolPluginId() { return TEST_DESCRIPTIONTOOL_PLUGIN_ID; } virtual const String GetResourceSymbol() { return String("MyDescriptionTool_desc"_s); } // return the resource description filename (without extension) virtual Bool InitTool(BaseDocument* doc, BaseContainer& data, BaseThread* bt); virtual void FreeTool(BaseDocument* doc, BaseContainer& data); virtual void InitDefaultSettings(BaseDocument* doc, BaseContainer& data); virtual Int32 GetState(BaseDocument* doc); virtual Bool GetCursorInfo(BaseDocument* doc, BaseContainer& data, BaseDraw* bd, Float x, Float y, BaseContainer& bc); virtual TOOLDRAW Draw(BaseDocument* doc, BaseContainer& data, BaseDraw* bd, BaseDrawHelp* bh, BaseThread* bt, TOOLDRAWFLAGS flags); }; Bool MyDescriptionTool::InitTool(BaseDocument* doc, BaseContainer& data, BaseThread* bt) { if (!DescriptionToolData::InitTool(doc, data, bt)) return false; return true; } void MyDescriptionTool::FreeTool(BaseDocument* doc, BaseContainer& data) { DescriptionToolData::FreeTool(doc, data); } void MyDescriptionTool::InitDefaultSettings(BaseDocument* doc, BaseContainer& data) { DescriptionToolData::InitDefaultSettings(doc, data); } Int32 MyDescriptionTool::GetState(BaseDocument* doc) { return CMD_ENABLED; } Bool MyDescriptionTool::GetCursorInfo(BaseDocument* doc, BaseContainer& data, BaseDraw* bd, Float x, Float y, BaseContainer& bc) { return true; } TOOLDRAW MyDescriptionTool::Draw(BaseDocument* doc, BaseContainer& data, BaseDraw* bd, BaseDrawHelp* bh, BaseThread* bt, TOOLDRAWFLAGS flags) { return TOOLDRAW::HANDLES | TOOLDRAW::AXIS; } // ==================================== // Plugin Main // ==================================== Bool PluginStart(void) { ApplicationOutput("Test"_s); if (!RegisterCommandPlugin(TEST_COMMAND1_PLUGIN_ID, "CallCommand"_s, 0, AutoBitmap("Test.png"_s), "MyCommand1"_s, NewObjClear(MyCommand1))) ApplicationOutput("Test - failed registering CommandData"); if (!RegisterCommandPlugin(TEST_COMMAND2_PLUGIN_ID, "SetAction"_s, 0, AutoBitmap("Test.png"_s), "MyCommand2"_s, NewObjClear(MyCommand2))) ApplicationOutput("Test - failed registering CommandData"); if (!RegisterToolPlugin(TEST_DESCRIPTIONTOOL_PLUGIN_ID, "Test - MyDescriptionTool"_s, 0, AutoBitmap("Test.png"_s), "MyDescriptionTool"_s, NewObjClear(MyDescriptionTool))) ApplicationOutput("Test - failed registering DescriptionTool"); return true; } void PluginEnd(void) { } Bool PluginMessage(Int32 id, void * data) { switch (id) { case C4DPL_INIT_SYS: if (!g_resource.Init()) return false; return true; case C4DMSG_PRIORITY: return true; case C4DPL_BUILDMENU: break; case C4DPL_ENDACTIVITY: return true; } return false; }
res/description/MyDescriptionTool_desc.h
#ifndef MYDESCRIPTIONTOOL_DESC_H__ #define MYDESCRIPTIONTOOL_DESC_H__ #endif // MYDESCRIPTIONTOOL_DESC_H__
res/description/MyDescriptionTool_desc.res
CONTAINER MyDescriptionTool_desc { NAME MyDescriptionTool_desc; }
res/strings_en-US/MyDescriptionTool_desc.str
STRINGTABLE MyDescriptionTool_desc { MyDescriptionTool_desc "MyDescriptionTool"; }
I don't have a solution for you and this all sounds really weird, but have you tried to retrieve the plugin node (i.e. your description plugin) associated with the plugin id and
FindPlugin
at the pointSetAction
bugs out? If you also retrieve the node for the brush tool thingy withFindPlugin
, you will at least know, that the problem is not exclusive toSetAction
.Cheers,
zipit
@zipit said in First Time calling SetAction does show the Brush tool's AM:
... have you tried to retrieve the plugin node (i.e. your description plugin) associated with the plugin id and
FindPlugin
bugs out? ...Yes, I had done that to check if the
DescriptionToolData
had been registered correctly.
The obtainedBasePlugin
contains the expected name and ID.However, the Brush tool, which I originally assumed to be the "Brush modeling tool", actually seems to be the "Brush tool for painting texture" (ID = 170134). And apparently that isn't a
PLUGINTYPE::TOOL
but aPLUGINTYPE::COMMAND
jeah, that is all very mysterious ;) One possible solution could be to retrieve the
BasePlugin
viaFindPlugin
(as this seems to work) and write that node to the active object manager viaActiveObjectManager_SetObject
, assuming you are just after setting an active tool without the implicationsCallCommand
comes with.Cheers,
zipit
One thing I forgot to mention is that when performing the
SetAction
the active tool is indeed the expected one. Except that the AM doesn't show it's attributes.On the other hand when performing an
with theBasePlugin
obtained viaFindPlugin
I do indeed get the attributes shown in the AM of the baseplugin. However, at that point the desired baseplugin is NOT the active tool.
And doing both (SetAction and ActiveObjectManager_SetObject) does again set the desired tool, but the AM then shows the Brush tool attributes ... weird indeed.It seems to be also reproducible with any tool. So, I tried with the ID_MODELING_ROTATE and obtain the same weird result ... but it reduces the amount of code needed to reproduce, as I can skip the whole
DescriptionToolData
and all its description resource files.Reduced code below:
#include "c4d.h" #define TEST_COMMAND1_PLUGIN_ID 1000001 #define TEST_COMMAND2_PLUGIN_ID 1000002 // ==================================== // CommandDatas // ==================================== // MyCommand1 - does perform a CallCommand to active the DescriptionTool class MyCommand1 : public CommandData { INSTANCEOF(MyCommand1, CommandData) public: virtual Bool Execute(BaseDocument* doc); }; Bool MyCommand1::Execute(BaseDocument* doc) { CallCommand(ID_MODELING_ROTATE); return true; } // MyCommand2 - does perform a SetAction to active the DescriptionTool class MyCommand2 : public CommandData { INSTANCEOF(MyCommand2, CommandData) public: virtual Bool Execute(BaseDocument* doc); }; Bool MyCommand2::Execute(BaseDocument* doc) { doc->SetAction(ID_MODELING_ROTATE); return true; } // ==================================== // Plugin Main // ==================================== Bool PluginStart(void) { ApplicationOutput("Test"_s); if (!RegisterCommandPlugin(TEST_COMMAND1_PLUGIN_ID, "CallCommand"_s, 0, AutoBitmap("Test.png"_s), "MyCommand1"_s, NewObjClear(MyCommand1))) ApplicationOutput("Test - failed registering CommandData"); if (!RegisterCommandPlugin(TEST_COMMAND2_PLUGIN_ID, "SetAction"_s, 0, AutoBitmap("Test.png"_s), "MyCommand2"_s, NewObjClear(MyCommand2))) ApplicationOutput("Test - failed registering CommandData"); return true; } void PluginEnd(void) { } Bool PluginMessage(Int32 id, void * data) { switch (id) { case C4DPL_INIT_SYS: if (!g_resource.Init()) return false; return true; case C4DMSG_PRIORITY: return true; case C4DPL_BUILDMENU: break; case C4DPL_ENDACTIVITY: return true; } return false; }
Hi I can indeed confirm your issue, However, I did remember we also faced this issue during the R22 dev cycle and it is now fixed.
I will get in touch with the development team to know if there is any workaround applicable to your code.Cheers,
Dev team confirmed this issue is resolved as a side effect of the document mode merging in R22 but they didn't remember exactly why it happened.
I will try to take a look, but since there is an alternative (CallCommand, I know it is not optional because it screws the undo). I will put it as low prio on my side to look at and will be back (don't expect before the end of the week/start of next week).Cheers,
@m_adam
Sorry to say butCallCommand
is not an option, as in my specific case theDescriptionTool
I want to activate is a hidden plugin, and CallCommand cannot execute hidden ones.
I understand the fact thatCallCommand
cannot call hidden plugins, and I don't assume this to be a bug. But ifSetAction
is an issue to use, andCallCommand
doesn't execute as expected ... then what is one supposed to use?
Hm,
I never mentioned this, because I thought it is obvious, but since the thread has somehow come to a pass: Have you ever tried to exploit the fact that selecting two tools in row seems to solve the problem? I.e. first select some dummy tool and then the tool you actually want to select?
zipit
@zipit
I did try to activate a tool when initializing the plugin ... didn't make any difference.But to answer your actual question, I just tried the following:
doc->SetAction(ID_MODELING_ROTATE); doc->SetAction(ID_MODELING_MOVE); doc->SetAction(myPluginID);
Sadly, no difference, the brush tool still gets shown into the AM.
I am not sure if we are talking about the same thing,
I meant (as extra lazy pseudo-code).edit: Jeah, just like that. But you could try to give Cinema some time to catch up and invoke an
EventAdd()
ordoc->ExecutePasses
between the tool activations.Cheers,
zipit
Hi @C4DS I tracked it down a bit.
First of all this issue appears only if you are in BodyaPaint Layout mode.The main problem is that in R21 and previous versions, there is 2 tool logics (For BodyPaint and for Classic one) and more problematic, 2 different attribute manager, while in S22 there is only 1 attribute manager.
The issue in R21 is that if there is no Mode selected, and you are in BP mode, SetAction assume that you want to define the BodyPaint Manager and command, so if you define previously the mode to a Polygon mode it will set is to the one you expect.
doc->SetMode(Mpoints); doc->SetAction(ID_MODELING_ROTATE); SyncMessage(EVMSG_TOOLCHANGED, ID_MODELING_ROTATE);
Defining the Mode to a modeling mode and make sure to also send EVMSG_TOOLCHANGED this way the internal state of command manager for BP will also be updated(otherwise you may see the command jump).
@m_adam said in First Time calling SetAction does show the Brush tool's AM:
Nope!
I am simply starting the application in its default state. The default startup layout, with the default move tool selected.However, I agree that in the default state the Object Model mode is active So, if I indeed perform a mode change to set it to points (probably also edges or polygons will work) I can see the
SetAction
bringing the expected tool settings in the AM.
So, this might be a solution:- Switch mode to points/edge/polygon
- SetAction
- Switch to orginal mode
This works:
const Int32 currentMode = doc->GetMode(); // only change mode if current one is different from Mpoints, Medges, Mpolygons or Mpolyedgepoint doc->SetMode(Mpoints); doc->SetAction(MYTOOL_PLUGINID); GeSyncMessage(EVMSG_TOOLCHANGED, MYTOOL_PLUGINID); doc->SetMode(currentMode);
Thanks for the hint.
EDIT:
FYI, note that I have only tested this solution on R20, not R21, but I assume it will behave identical.
And I did test only on R21 so be sure to check again because I wasn't able to reproduce as you said with default layout in R21.
Maxime.I am using R21.207 and with default layout see the brush tool in the AM (identical to what happens with R20.059). For safety, I have now tested your solution on R21 and works as expected.
