Hello there!
I'm not quite sure if the issue I'm having is already explained elsewhere, although I did try to find guides and articles on this, but found nothing sufficient enough.
So I implemented a SceneHook which writes data when a document is written and reads data when a document loads. That's fine and not the issue I'm having.
The data that this SceneHook handles cannot be put into a container, but also has no effect on the contents of the scene. When a scene is now saved with that data internal to this SceneHook, it cannot be opened anymore without the plugin being installed, as Cinema reports an 'incorrect file structure' otherwise, basically corrupting every scene saved while this plugin is installed.
I was under the impression that Cinema simply ignores data for nodes from a missing plugin, so I guess my implementation of the Write() function is just not quite right.
Is there any documentation as to how reading and writing should be implemented, or is that actually expected behaviour?
