Best way to fill a maxon::BaseArray
Sometimes I feel like a C++ dinosaur.
While the range-based for loop is available for quite a long time, I only discovered it a few years ago.
Same for some other new and exciting stuff ...Probably known to many for a while (or longer), the following isn't yet set in stone into my aging memory.
// example 1 int myValues[] = { 1, 2, 3, 4 }; // example 2 std::vector<int> myValues = { 1, 2, 3, 4 };
Quite like how these options can reduce code.
Wondering how to initialize amaxon::BaseArray<>
with known values, with least amount of code ?
Example 1 is the initialization of a C-array from a brace-enclosed list.
Example 2 is the construction of a
std::vector
object using an initializer list.So, does
maxon::BaseArray
has initializer list constructors or methods?Looking at the API, it seems it does not have such a constructor, but methods handling
std::initializer_list
. So you can actually write:maxon::BaseArray<maxon::Int> testArray; testArray.Append({ 1,2,3 }) iferr_return;
Kudos to @PluginStudent saying in Best way to fill a maxon::BaseArray:
maxon::BaseArraymaxon::Int testArray;
testArray.Append({ 1,2,3 }) iferr_return;I confirm that only BaseArray::Append(), BaseArray::Insert() and BaseArray::Insert() can use an initialization list to add data to a BaseArray.
Cheers, R
@PluginStudent
@r_gigante
Thanks for chipping in.If no more needs to be added I will set this as solved.
Just saw this thread...
What if I want to fill the whole array with the same value?
In Python this would be:
arrayOfOnes = [1] * 10000
Frank
Unfortunately, differently from std lib where it's possible to define and init a vector pretty easily using one-line statement(
std::vector<int> a (10, 100);
) this looks like being not currently possible with maxon::BaseArray() and you need to make it the usual way.Best, R
