Sample a shader in 3D space
this seems to be an old topic, and I have found several search results for this, but none really helped. I'm trying to sample a shader from within
ObjectData::GetVirtualObjects()
.It works fine with shaders that are calculated in UV space (e.g. Bitmap Shader, and most of the "Surface" shaders, like Galaxy, Planet, Tiles, Sunburst, etc...), but it does not seem to work with shaders that need a VolumeData (e.g. Surface/Earth, Wood, Marble, etc...). The Noise shader works, regardless of what space I set it to, but as the result does not change when I set it to "World" or "UV", I suspect it's only calculating in UV space.
I tried making up a mock
VolumeData
, but it does not work yet. What am I missing? Is this the preferred way of doing it anyway?Here is the code:
// Prepare InitRenderStruct InitRenderStruct irs; irs.doc = doc; irs.document_colorprofile = DOCUMENT_COLORPROFILE_SRGB; irs.flags = INITRENDERFLAG::TEXTURES; irs.time = doc->GetTime(); // Inititalize shader if (shader->InitRender(irs) != INITRENDERRESULT::OK) return maxon::OutOfMemoryError(MAXON_SOURCE_LOCATION, "Could not initialize shader!"_s); const Float gridWidthI = Inverse((Float)gridWidth); const Float gridHeightI = Inverse((Float)gridHeight); // Create an array with as many ChannelDatas as we have threads available maxon::BaseArray<ChannelData> channelData; channelData.Resize(GeGetCurrentThreadCount(), maxon::COLLECTION_RESIZE_FLAGS::FIT_TO_SIZE) iferr_return; const Float time = doc->GetTime().Get(); // Prepare ChannelDatas, and VolumeDatas for each thread auto shaderInit = [&channelData, &generationParameters, &time] (maxon::ParallelFor::BreakContext& context) -> maxon::Result<void> { const Int threadIndex = context.GetLocalThreadIndex(); // Create mock ChannelData ChannelData &channelDataRef = channelData[threadIndex]; channelDataRef.n = Vector(0.0, 1.0, 0.0); channelDataRef.d = Vector(0.001); channelDataRef.t = time; channelDataRef.texflag = 0; channelDataRef.off = 0.0; channelDataRef.scale = 0.01; // Create mock VolumeData VolumeData *volumeData = VolumeData::Alloc(); if (!volumeData) return maxon::OutOfMemoryError(MAXON_SOURCE_LOCATION, "Could not allocate VolumeData for shader sampling!"_s); channelDataRef.vd = volumeData; TexData *texData = TexData::Alloc(); if (!texData) return maxon::OutOfMemoryError(MAXON_SOURCE_LOCATION, "Could not allocate TexData for shader sampling!"_s); texData->m = generationParameters.parentGeneratorMg; texData->im = generationParameters.parentGeneratorMgI; texData->Init(); volumeData->tex = texData; volumeData->orign = channelDataRef.n; volumeData->bumpn = channelDataRef.n; volumeData->dispn = channelDataRef.n; volumeData->n = channelDataRef.n; volumeData->time = time; volumeData->delta = channelDataRef.d; return maxon::OK; }; // Sample the shader auto shaderWorker = [&gridRef, &shader, &channelData, &generationParameters, &thread, gridWidth, gridWidthI, gridHeightI] (Int y, maxon::ParallelFor::BreakContext& context) -> maxon::Result<void> { const Int threadIndex = context.GetLocalThreadIndex(); ChannelData &sampleCd = channelData[threadIndex]; for (Int x = 0; x < gridWidth; ++x) { sampleCd.p = Vector((Float)x * gridWidthI, (Float)y * gridHeightI, 0.0); if (sampleCd.vd) sampleCd.vd->p = Vector(x, y, 0.0); Vector sampledColor = shader->Sample(&sampleCd).GetAverage(); /* do something with sampledColor... */ } return maxon::OK; }; // Free the allocated structures auto shaderFinalize = [&channelData] (maxon::ParallelFor::BreakContext& context) { for (maxon::BaseArray<ChannelData>::Iterator cdIt = channelData.Begin(); cdIt != channelData.End(); ++cdIt) { ChannelData &cd = *cdIt; // TexData::Free(cd.vd->tex): VolumeData::Free(cd.vd); } }; maxon::ParallelFor::Dynamic<maxon::ParallelFor::BreakContext>(0, gridHeight, shaderInit, shaderWorker, shaderFinalize) iferr_return; shader->FreeRender();
Thanks for any help!
FrankP.S.: By the way, using this on an "Effects -> Spectral" shader crashes Cinema.
No solution to your question, but there is information in the manuals: Sampling a Shader.
And also some hints regarding VolumeData here: InitRenderStruct::vd.
Thanks for your reply!
Yeah, I guess
Render::GetInitialVolumeData()
, which is mentioned in your second link, would be exactly what I need here... However, inObjectData::GetVirtualObjects()
, there is no such thing, so I have to make up my own data...
I am not quite sure if I understand your question correctly and also am unclear on what you would consider "not working" in the context of sampling a volumetric shader.
However, what stood out to me in your code, is that you only do sample in a slice of the volume, basically treat the shader like a 2D-Shader, which might have side effects as your sampled shaders might simply only return the zero vector in that slice (here comes up the question of what is not working).
Poking around in the Script Manager, I did not had any problems sampling the
Xwood
shader, at least the output looks meaningful.Cheers,
zipitimport c4d def main(): """ """ shader = c4d.BaseList2D(c4d.Xwood) irs = c4d.modules.render.InitRenderStruct(doc) shader.InitRender(irs) for i in range(10): n = i / 9. cd = c4d.modules.render.ChannelData() cd.p = c4d.Vector(0, 0, n) print shader.Sample(cd) shader.FreeRender() if __name__=='__main__': main()
Vector(0.187, 0.077, 0.03) Vector(0.171, 0.07, 0.028) Vector(0.091, 0.038, 0.015) Vector(0.163, 0.067, 0.027) Vector(0.255, 0.105, 0.041) Vector(0.275, 0.113, 0.044) Vector(0.314, 0.13, 0.05) Vector(0.249, 0.103, 0.04) Vector(0.095, 0.039, 0.016) Vector(0.318, 0.131, 0.05)
Hi & thanks for your reply.
@zipit said in Sample a shader in 3D space:
I get only one value, regardless of the sample coordinates.
z
is0.0
because I'm sampling at positions on a plane.ChannelData::p
is, according to the SDK docs, only in UVW space, anyway (that's why I multiply the X and Y grid coordinate with the inverse X and Y size, so my actual sample values are in the range of0.0
...1.0
). And sampling those positions works. For 3D shaders, as far as I always understood it, thesampleCd.vd->p
is the one that counts, as that is actually a position in 3D space.def main():
shader.InitRender(irs)for i in range(10): n = i / 9. cd = c4d.modules.render.ChannelData() cd.p = c4d.Vector(0, 0, n) print shader.Sample(cd) shader.FreeRender()
if name=='main':
Vector(0.318, 0.131, 0.05)Hmm, that looks meaningful in deed. I still wonder why I get nothing out of the Wood shader and others.
Hm,
I might be wrong about this, but I always thought that
VolumeData.p
is a sample position in object space andChannelData.p
is the sample position in uvw space. The latter would lie in the half interval uv(w) coordinates are normally defined in, while the former would lie in an arbitrary interval, depending on the bounding box of the sampled geometry (i.e.0 <= c <= 1
is not guaranteed to be met for the components ofVolumeData.p
). So a geometry-agnostic shader should not care aboutVolumeData.p
.Also note that I did deliberately only sample on the z-axis in my example and still get a varying output. If your premise would be true, I should get the same vector for all ten calls.
zipit
Hi sorry for not answering you earlier, I just wanted to inform you I reached the development team about it especially since you use multi-threading, and sampling a shader with Multiple thread is different (for example in my case your code does not work even on a 2D gradient).
I have a property but which doesn't support all shaders (especially Layer shader).So I will keep you in touch when I have more news.
Sorry for the delay, this took me a bit more time than expected.
I would say @zipit is completely right here, but since you are using multi threads you have to attach a FakeVolumeData for each thread since some shader really needs and output their result according to this VolumeData.
Here a complete example.
// class that hold per thread sampling data class ShaderSampler { public: BaseContainer _rdc; BaseObject* _camera = nullptr; ChannelData _channelData; ::Ray _ray; VolumeData* _volumeData = nullptr; ShaderSampler(){}; ~ShaderSampler() { if (_camera) BaseObject::Free(_camera); if (_volumeData) VolumeData::Free(_volumeData); }; void SetSamplingContext(const Vector& uv, const Vector& delta) { VolumeData& volumeData = *_volumeData; const Vector d = Vector(delta.x, delta.y, delta.z); _channelData.d = d; volumeData.delta = d; const Vector p = Vector(uv.x, uv.y, uv.z); _channelData.p = p; volumeData.uvw = p; volumeData.p = p; volumeData.pp[0] = p; volumeData.pp[1] = p; volumeData.pp[2] = p; _ray.p = p; _ray.pp[0] = p; _ray.pp[1] = p; _ray.pp[2] = p; } }; static maxon::Result<void> SampleMaterialBis(BaseDocument* doc) { iferr_scope; //Get the BaseShader linked in the color shader of the first material BaseShader* shader; MAXON_SCOPE { // Get the first material and check its a Cinema 4D default material BaseMaterial* firstMat = doc->GetFirstMaterial(); CheckState(firstMat != nullptr, "Failed to get the first material"); CheckState(firstMat->IsInstanceOf(Mmaterial), "material is not a default c4d material"); // look for the material BaseContainer and the BaseList2D associated to the color param BaseContainer* matBC = firstMat->GetDataInstance(); CheckState(matBC != nullptr, "Failed to get the BaseContainer"); BaseList2D* matColorBL = matBC->GetLink(MATERIAL_COLOR_SHADER, doc); CheckState(matColorBL != nullptr, "Failed to get the Color Shader"); // cast to BaseShader shader = (BaseShader*)matColorBL; } // Allocate and init the InitRenderStruct // This is important to init with valid FakeVolumeData since some shaders needs them. InitRenderStruct irs; VolumeData* volumeData = VolumeData::Alloc(); BaseObject* camera = BaseObject::Alloc(Ocamera); CheckState(volumeData != nullptr, "Failed to initialize volume data"); CheckState(camera != nullptr, "Failed to initialize camera"); MAXON_SCOPE { BaseContainer renderData; const Int threadIndex = maxon::JobRef::GetCurrentWorkerThreadIndex(); renderData.SetInt32(RDATA_VDFAKE_CURRENTTHREAD, threadIndex); renderData.SetInt32(RDATA_VDFAKE_THREADCOUNT, (Int32)GeGetCurrentThreadCount()); const Bool attached = C4DOS.Sh->AttachVolumeDataFake(volumeData, camera, renderData, nullptr); CheckState(attached == true, "Failed to attach volume data"); irs.vd = volumeData; irs.flags = INITRENDERFLAG::TEXTURES; irs.time = doc->GetTime(); irs.docpath = doc->GetDocumentPath(); irs.thread = GeGetCurrentThread(); COLORSPACETRANSFORMATION transform = COLORSPACETRANSFORMATION::NONE; // check if linear workflow is enabled if (irs.linear_workflow) transform = COLORSPACETRANSFORMATION::LINEAR_TO_SRGB; const INITRENDERRESULT initResult = shader->InitRender(irs); CheckState(initResult == INITRENDERRESULT::OK, "Shader init failed"); } // Allocate a list of ShaderSampler to store VolumeData and ChannelData per thread maxon::BaseArray<ShaderSampler*> samplers; MAXON_SCOPE { for (Int32 i = 0; i < GeGetCurrentThreadCount(); i++) { ShaderSampler* sampler = NewObjClear(ShaderSampler); const Int threadIndex = maxon::JobRef::GetCurrentWorkerThreadIndex(); sampler->_rdc.SetInt32(RDATA_VDFAKE_CURRENTTHREAD, threadIndex); sampler->_rdc.SetInt32(RDATA_VDFAKE_THREADCOUNT, GeGetCurrentThreadCount()); sampler->_camera = BaseObject::Alloc(Ocamera); CheckState(sampler->_camera != nullptr, "Failed to initialize camera"); sampler->_volumeData = VolumeData::Alloc(); CheckState(sampler->_volumeData != nullptr, "Failed to initialize volume data"); const Bool attached = C4DOS.Sh->AttachVolumeDataFake(sampler->_volumeData, sampler->_camera, sampler->_rdc, nullptr); CheckState(attached == true, "Failed to attach volume data"); samplers.Append(sampler) iferr_return; } } // Worker lambda to build the grid Int gridSize = 64; // Create a BaseArray of matrices and colors (to store the results of our sampling, and visualize them in an instanceObject) maxon::BaseArray<Matrix> matrices; maxon::BaseArray<maxon::Color64> colors; // * 3 because we store the data for x,y,z axis in one big array matrices.Resize(gridSize * gridSize * gridSize) iferr_return; colors.Resize(gridSize * gridSize * gridSize) iferr_return; auto worker = [&samplers, &shader, &matrices, &colors, &gridSize](UInt y) { // Retrieve the current sampler data for the current thread const Int threadIndex = maxon::JobRef::GetCurrentWorkerThreadIndex(); ShaderSampler* sampler = samplers[threadIndex]; if (sampler == nullptr) return; for (Int32 z = 0; z < gridSize; ++z) { for (Int32 x = 0; x < gridSize; ++x) { // Map 3D array to a 1D array Int32 arrayId = (z * gridSize * gridSize) + (y * gridSize) + x; matrices[arrayId] = MatrixMove(Vector(x, y, z)); // Define where we want to sample Vector uvw = Vector( double(x) / double(gridSize), double(y) / double(gridSize), double(z) / double(gridSize) ); Vector delta = Vector(0.01, 0.01, 0.01); sampler->SetSamplingContext(uvw, delta); // sample const Vector sampledValue = shader->Sample(&sampler->_channelData); // Store the color result of the sampling operation colors[arrayId] = maxon::Color64(sampledValue.x, sampledValue.y, sampledValue.z); } } }; // Execute worker maxon::ParallelFor::Dynamic(0, gridSize, worker, GeGetCurrentThreadCount()); // Free samplers MAXON_SCOPE { for (Int32 i = 0; i < GeGetCurrentThreadCount(); i++) { ShaderSampler* sampler = samplers[i]; if (sampler != nullptr) { DeleteObj(sampler); samplers[i] = nullptr; } } } // call the FreeRender to release allocated memory used for sampling shader->FreeRender(); VolumeData::Free(volumeData); BaseObject::Free(camera); // Create a Multi-Instance object with the matrix and the color information to visualize them InstanceObject* const instance = InstanceObject::Alloc(); CheckState(instance != nullptr, "Failed to allocate an Instance Object"); MAXON_SCOPE { doc->InsertObject(instance, nullptr, nullptr); // Set to multi instance + to Points mode if (!instance->SetParameter(INSTANCEOBJECT_RENDERINSTANCE_MODE, INSTANCEOBJECT_RENDERINSTANCE_MODE_MULTIINSTANCE, DESCFLAGS_SET::NONE)) return maxon::UnexpectedError(MAXON_SOURCE_LOCATION); if (!instance->SetParameter(INSTANCEOBJECT_DRAW_MODE, INSTANCEOBJECT_DRAW_MODE_POINTS, DESCFLAGS_SET::NONE)) return maxon::UnexpectedError(MAXON_SOURCE_LOCATION); // Set data in the instance object instance->SetInstanceMatrices(matrices) iferr_return; instance->SetInstanceColors(colors) iferr_return; } EventAdd(EVENT::NONE); return maxon::OK; }
Thank you very much! I'll try that out ASAP!
Frank
Almost perfect, thanks. It kinda only works half ok, I noticed.
The thing is, all shaders are always sampled in UV space. I tried adding the 3D position data for sampling, too, by setting
volumeData.p
to the global position of the point to sample, inSetSamplingContext()
. but it is being ignored. For example, if the Shader is a Noise shader, I can set it to whatever space I want, the result is always the same.With my old code, that worked. It just couldn't sample certain shaders (Layer Shader, Earth Shader, etc). Now, those shaders work, but sampling seems restricted to UV space. How can I sample those shaders in Texture Space, Object Space, and World Space (Camera, Screen, and the others can be neglected)?
Thanks in advance,
Frank
