Despite I didn't want to ask you about that and fought much, I need help. Don't be offended, but Resource Descripion topic on CPP docs looks too stingy to dive into the theme and feel comfortable. The explanation makes the whole idea somehow clearer than before, but there are hidden underwater rocks around I can't identify, and the only info you can harvest is the line where the error is, but nothing about the cause. So:
Hi @intenditore, thanks for reaching out us.
Thanks to @PluginStudent and @zipit seems like you're now back on track. One additional note is to always check that the .resfile is coherently using tab or spaces but not a mix of the twos which could instead cause unexpected troubles.
.res
Best, R
enumerations in C-languages delimit their elements with commas, while statements are delimited by semicolons. So in your h(eader) file your enum should look something like this:
h
enum
enum { ONE=1, TWO=2, THREE=3, };
edit: To avoid any confusion here - the semicolons in the res and str files are correct. edit2: I overlooked the additional semicolons, your res file is also malformed.
res
str
Cheers, zipit
@zipit many thanks, it worked out! But... Not for long Again. I only added STATICTEXT entry and now I get "Error reading resource file.... TautoLayer.res line 8. What could be wrong... So confusing! Nope, we still need a guide
Elements in a resource file are delimited by their curly braces and their flags are delimited by semicolons. So you would have to get rid of the semicolons after the closing brackets in your screenshot, i.e. STATICTEXT YADAYADA { FLAG; ANOTHER_FLAG; } and not STATICTEXT YADAYADA { FLAG; ANOTHER_FLAG; };.
Edit: FYI there do exist manuals for Cinema's resource system. Some more complex stuff is not documented though.
General Resource Manual Specific Description Resource Manual (This is what you are doing right now).
I've studied those docs and couldn't get enough satisfaction
I've changed the semicolons for comas, and even deleted them all, but the error persists. I'm wondering what's happening there(
there are no commas in a res file and you will need semicolons to delimit your flags (and also CYCLE elements). I understand that the system can be a bit confusing, but you should either reread my comments more carefully or study existing resource files.
CYCLE
You have to remove the semicolons after an closing curly bracket in your screenshot. You will need to keep those delimiting your flags. The principal syntax in a res file is:
ELEMENT { FLAG; ANOTHER_FLAG; SUBELEMENT { FLAG; ANOTHER_FLAG; } }
I feel stupid. You tell me the right things but even when I used semicolons and seemingly screwed it all up it all still was functioning Anyway, this one works
But than I move the TXT_CREDIT to the top (changing ids accordingly!) and it gives two cycling errors relating to both .h (line and .res (line7) files
Docs don't give an answer
Pro Tip: your installation of Cinema C4D contains the resource\modules\ folder.
resource\modules\
In that folder, you find sub-folders. These sub-folders contain Cinema's resource files. So you actually have hundreds of example files for all of this.
And of course lots of examples on GitHub.
And BTW, in your *.h file you miss the comma in line 7 : " = 1001,"
" = 1001,"
Brah... Third time spent fighting with stupid typos! : @PluginStudent @zipit @r_gigante many thanks! I didn't assume you are using the same system inside the program and had no thought to take a look there! Seems adding the "," helped it. And, as I see, you must enumerate all the elements in your .h file, but though you can leave id blank. Thank you! %\
