I use the example from the Python Manual, to start a python script from C++. How can I pass additional variable to the python script. For example, a path?
I am not quite sure if do understand your question correctly. I assume with Python manual you are referring to this page. The example actually shows you how to expose two variable attributes (doc, op) and one constant attribute (__name__ ) in the dictionary of the executing module. So you could just copy the part for __name__ for your task of exposing a file name.
doc
op
__name__
If you were not referring to exposing an attribute in the dictionary of the module with "passing a variable to the script", you would have to elaborate what you exactly mean by that (at least for me).
Cheers and stay safe, zipit
Yes, I am referring to that page. I saw that statement, but I assumed it was the main definition for the python plugin.
// set __name__ = __main__ scope.Add("__name__"_s, maxon::Data("__main__"_s)) iferr_return;
If I understand you correctly, I can add different parameters with different values. For example:
// set __param1__ = "c:/temp" scope.Add("param1"_s, maxon::Data("c:/temp"_s)) iferr_return; scope.Add("param2"_s, maxon::Data(220)) iferr_return;
And yes, it works. Thanks.
yeah like that. __name__ is just another module bound constant attribute. It is a dunder attribute, signaling a special importance, indicated by its double underscores, but that is only a convention and not a functionality. You can set __name__ to anything you like, just like you could set __author__ to your favourite ice cream brand. The convention dictates that __name__ tells the script in which context is being executed, where __main__ should signal that the module is executed directly. You could set it to my_cpp for example, so that your scripts could react differently to being executed from your C++ code.
__author__
__main__
my_cpp
Cheers, zipit
