AttributeError: 'GUI' object has no attribute 'AddCheckBox'
Hey Guys,
I'm getting the error " AttributeError: 'GUI' object has no attribute 'AddCheckBox' " in my console, and I believe I'm bringing in the right libraries, I think...But, I cannot seem to find anything that's helping searching through forums and the c4d.gui info pages.
Maxime helped me understand the group concepts so thanks again for that. I commented out a lot of code to test things, but here's the current code that's throwing the error. Still a lot of learning to do, but I've been on this particular error for 2 hours now....oh fun haha
import c4d from c4d import gui, plugins, bitmaps, documents class GUI(gui.GeDialog): """ Creates the main graphical user interface of the plug-in """ ResourceFileGroup = 101 SettingFilegroup = 102 Label_Folders = 201 Label_Settings = 202 Label_ObjectsImport = 203 ResourceFolder = 301 MVRFileLocation = 302 AllCheckBox = 401 HangingPosCheckBox = 402 TrussCheckBox = 403 FixturesCheckBox = 404 GeometriesCheckBox = 405 ComboBox_ID = 1003 AddChild_1 = 1004 TextEdit = 1005 RadioGroup = 1006 RadioText = 1007 RadioChild = 1008 def CreateLayout(self): self.SetTitle("My Dialog") self.GroupBegin(self.ResourceFileGroup, 0 | 0) self.AddStaticText(self.TextEdit, c4d.BFH_SCALEFIT | c4d.BFV_TOP, 100, 25, "Source Files", 1) self.AddButton(self.ResourceFolder, c4d.BFH_LEFT | c4d.BFV_TOP, 125, 25, "Resource Folder") self.AddButton(self.MVRFileLocation, c4d.BFH_LEFT | c4d.BFV_TOP, 125, 25, "MVR File") self.GroupEnd() self.GroupBegin(self.ResourceFileGroup, 0 | 0) self.AddStaticText(self.TextEdit, c4d.BFH_SCALEFIT | c4d.BFV_TOP, 100, 25, "Settings", 1) self.AddCheckBox(self.AllCheckBox, c4d.BFH_LEFT | c4d.BFV_TOP, 125, 25, "All") self.GroupEnd() # if self.GroupBegin(self.SettingFilegroup, 0 | 0): # self.AddStaticText(self.TextEdit, 0 | 0, 100, 25, "Settings", 1) # self.AddCheckBox(self.AllCheckBox, c4d.BFH_LEFT | c4d.BFV_TOP, 125, 25, "All") # self.GroupEnd() # self.SetTitle("CAV MVR IMPORTER") # Set dialog title # self.AddRadioText(self.Label_Folders, c4d.BFH_LEFT | c4d.BFV_TOP, 0, 0, "Source Files") # self.AddRadioText(self.Label_Settings, c4d.BFH_CENTER, 0, 0, "Settings") # self.AddRadioText(self.Label_Settings, c4d.BFH_RIGHT, 0, 0, "Objects To Import") # self.AddButton(self.ResourceFolder, c4d.BFH_LEFT | c4d.BFV_TOP, 125, 25, "Resource Folder") # self.AddButton(self.MVRFileLocation, c4d.BFH_LEFT | c4d.BFV_TOP, 125, 25, "MVR File") # self.AddComboBox(self.ComboBox_ID, 0 | 0, 100, 25, True, True) # self.AddChild(self.ComboBox_ID, self.AddChild_1, "Drop Down 1") # self.AddRadioGroup(self.RadioGroup, c4d.BFH_SCALE | c4d.BFV_SCALE, 1, 3) # Create a Group, its usefull because here we adds the StaticText Gadget and to make it appears again # LayoutChanged needs to be called, which work only a group. # if self.GroupBegin(self.TextEditGroup, c4d.BFH_SCALEFIT | c4d.BFV_TOP): # self.AddStaticText(self.TextEdit, c4d.BFH_SCALEFIT | c4d.BFV_TOP, 100, 25, "", 1) # self.HideElement(self.TextEdit, True) # self.GroupEnd() # def Command(self, id, msg): # # RESOURCE FOLDER BUTTON # if id == 201: # fn_ResourceFolder = c4d.storage.LoadDialog() # # Unhides the Text element # self.HideElement(self.TextEdit, False) # # Checks if its a str, then display the file path # if isinstance(fn, str): # # Unhides the Text element # self.HideElement(self.TextEdit, False) # # SET THE STRING # self.SetString(self.TextEdit, fn) # # If its not a string, the user cancelled # else: # self.SetString(self.TextEdit, "User cancelled") # # Notify the layout of the group changed, this will invalidate the group and it will be then redraw # # This is needed because the UI was hidden, if the Ui is not hidden then there is no need for it # self.LayoutChanged(self.TextEditGroup) # # MVR FILE BUTTON # if id == 202: # fn_MVRFileLocation = c4d.storage.LoadDialog() # # Unhides the Text element # self.HideElement(self.TextEdit, False) # # Checks if its a str, then display the file path # if isinstance(fn, str): # # Unhides the Text element # self.HideElement(self.TextEdit, False) # # SET THE STRING # self.SetString(self.TextEdit, fn) # # If its not a string, the user cancelled # else: # self.SetString(self.TextEdit, "User cancelled") # # Notify the layout of the group changed, this will invalidate the group and it will be then redraw # # This is needed because the UI was hidden, if the Ui is not hidden then there is no need for it # self.LayoutChanged(self.TextEditGroup) # print fn_MVRFileLocation def main(): # Test dialog diag = GUI() diag.Open(dlgtype=c4d.DLG_TYPE_MODAL, defaultw=1000, defaulth=400) # Execute main() if __name__ == '__main__': main()
Thanks again for any insight.
Cheers!
MattG
According to the docs: AddCheckbox().
Not "
AddCheckBox()
Not "
AddCheckBox()
Well Uh.....Yea.....Guess I should take a break......Thanks for the point out of the lower case b........
This is solved. Thanks Plugin Student!
Cheers!
MattG
