I am a bit confused about the SDK example CommandLineRendering. I compiled it ok, using R20, Windows 10 and VC++ 2017. I can see that it is loaded / started.
Bool PluginStart() { GePrint("CommandLineRendering Start in PluginStart"_s); return true; }
But it looks as if it is not called. It gets the parameters ok: Command line arguments : "-nogui" "-sdk_render" "cube.c4d" But I get the message "Warning: Unknown arguments: -sdk_render"
So it seems as if CommandLineRendering() is not called.
Here the command I use to start.
"C:\Program Files\Maxon\CINEMA 4D R20.026\CINEMA 4D.exe" -nogui -sdk_render cube.c4d" > "C:\Program Files\Maxon\CINEMA 4D R20.026\plugins\CommandLineRendering\report.txt"
I did not change anything in CommandLineRendering() Here main.cpp, that I changed a bit.
#include "main.h" #include "c4d.h" Bool PluginStart() { GePrint("CommandLineRendering Start in PluginStart"_s); return true; } void PluginEnd() { //FreeGLTestObject(); //FreeExampleSNHook(); //FreePaintAdvanced(); } Bool PluginMessage(Int32 id, void* data) { switch (id) { case C4DPL_INIT_SYS: { if (!g_resource.Init()) return false; // don't start plugin without resource // register example datatype. This is happening at the earliest possible time // if (!RegisterExampleDataType()) // return false; // serial hook example; if used must be registered before PluginStart(), best in C4DPL_INIT_SYS // if (!RegisterExampleSNHook()) return false; return true; } case C4DMSG_PRIORITY: // react to this message to set a plugin priority (to determine in which order plugins are initialized or loaded // SetPluginPriority(data, mypriority); return true; case C4DPL_BUILDMENU: // react to this message to dynamically enhance the menu // EnhanceMainMenu(); break; case C4DPL_COMMANDLINEARGS: // sample implementation of command line rendering: // CommandLineRendering((C4DPL_CommandLineArgs*)data); // react to this message to react to command line arguments on startup /* { C4DPL_CommandLineArgs *args = (C4DPL_CommandLineArgs*)data; Int32 i; for (i = 0; i<args->argc; i++) { if (!args->argv[i]) continue; if (!strcmp(args->argv[i],"--help") || !strcmp(args->argv[i],"-help")) { // do not clear the entry so that other plugins can make their output!!! ApplicationOutput("\x01-SDK is here :-)"); } else if (!strcmp(args->argv[i],"-SDK")) { args->argv[i] = nullptr; ApplicationOutput("\x01-SDK executed:-)"); } else if (!strcmp(args->argv[i],"-plugincrash")) { args->argv[i] = nullptr; *((Int32*)0) = 1234; } } } */ break; case C4DPL_EDITIMAGE: /*{ C4DPL_EditImage *editimage = (C4DPL_EditImage*)data; if (!data) break; if (editimage->return_processed) break; ApplicationOutput("C4DSDK - Edit Image Hook: "+editimage->imagefn->GetString()); // editimage->return_processed = true; if image was processed }*/ return false; } return false; }
The plugin, is it a real plugin(?), is also not registered?
Hi @pim thanks for reaching out us.
With regard to your request, well just having the "special" command-line args recognized is as easy as uncommenting this line.
It's indeed a working plugin and it should not be registered since it's not a plugin but rather a behavior defined when a C4DPL_COMMANDLINEARGS is intercepted.
Best, R
Ok, thank you. I should have spotted that myself.
-Pim
