Create a download progress bar in python
I found the following functions on a stackoverflow topic, and I want to apply it on c4d.gui.GeDialog.
I put more details in the code:import urllib2 def chunk_report(bytes_so_far, chunk_size, total_size): percent = float(bytes_so_far) / total_size percent = round(percent*100, 2) sys.stdout.write("Downloaded %d of %d bytes (%0.2f%%)\r" % (bytes_so_far, total_size, percent)) if bytes_so_far >= total_size: sys.stdout.write('\n') def chunk_read(response, chunk_size=8192, report_hook=None): total_size = response.info().getheader('Content-Length').strip() total_size = int(total_size) bytes_so_far = 0 while 1: chunk = response.read(chunk_size) bytes_so_far += len(chunk) if not chunk: break if report_hook: report_hook(bytes_so_far, chunk_size, total_size) return bytes_so_far class Update(c4d.gui.GeDialog): UPDATE_BTN = 1000 PROGRESS = 1001 PROGRESSBAR = 1002 state = "" def CreateLayout(self) : self.AddButton(self.UPDATE_BTN, flags = c4d.BFH_LEFT, inith = 13, name = "Update") self.AddStaticText(self.PROGRESS, flags=c4d.BFH_SCALEFIT, initw=0, inith=0, name=self.state, borderstyle=0) # I want take the percentage value from the function chunk_report() and apply it to the following CUSTOMGUI_PROGRESSBARCUSTOMGUI_PROGRESSBAR self.GroupBegin(id=0, flags=c4d.BFH_LEFT, cols=1, rows=0) self.GroupBorderNoTitle(c4d.BORDER_THIN_IN) self.AddCustomGui(self.PROGRESSBAR, c4d.CUSTOMGUI_PROGRESSBAR, "", c4d.BFH_SCALEFIT|c4d.BFV_SCALEFIT,200, 8) self.GroupEnd() def Command(self, id, msg): if id == self.UPDATE_BTN : filedata = urllib2.urlopen('https://www.domainname.com/file.zip') chunk_read(filedata, report_hook= chunk_report) self.SetString(self.PROGRESS, "Or showing the write result of chunk_report() function here?") # <---
Thanks
I found the solution.import urllib2 class Update(c4d.gui.GeDialog): UPDATE_BTN = 1000 PROGRESS = 1001 PROGRESSBAR = 1002 state = "" def CreateLayout(self) : self.AddButton(self.UPDATE_BTN, flags = c4d.BFH_LEFT, inith = 13, name = "Update") self.AddStaticText(self.PROGRESS, flags=c4d.BFH_SCALEFIT, initw=0, inith=0, name=self.state, borderstyle=0) # How to taking the percentage value from the function chunk_report() and apply it to the following CUSTOMGUI_PROGRESSBAR self.GroupBegin(id=0, flags=c4d.BFH_LEFT, cols=1, rows=0) self.GroupBorderNoTitle(c4d.BORDER_THIN_IN) self.AddCustomGui(self.PROGRESSBAR, c4d.CUSTOMGUI_PROGRESSBAR, "", c4d.BFH_SCALEFIT|c4d.BFV_SCALEFIT,200, 8) self.GroupEnd() def chunk_read(self, response, chunk_size=8192): total_size = response.info().getheader('Content-Length').strip() total_size = int(total_size) bytes_so_far = 0 progressMsg = c4d.BaseContainer(c4d.BFM_SETSTATUSBAR) progressMsg[c4d.BFM_STATUSBAR_PROGRESSON] = True while 1: chunk = response.read(chunk_size) bytes_so_far += len(chunk) if not chunk: break percent = float(bytes_so_far) / total_size percent = round(percent*100, 2) progressMsg[c4d.BFM_STATUSBAR_PROGRESS] = percent/100 self.SendMessage(self.PROGRESSBAR, progressMsg) self.SetString(self.PROGRESS, percent) def Command(self, id, msg): if id == self.UPDATE_BTN : filedata = urllib2.urlopen('https://www.domainname.com/file.zip') self.chunk_read(filedata)
tx, but how can i use this in a simple scenario?
it doesnt do anything when pasted into the script manager
Here is a full example that you can test it on script manager:# The following code allow to download a file and then save it on the desktop import c4d, os, math, urllib2 from c4d import gui PLUGIN_ID = 99999999 class MyDialog(gui.GeDialog): DOWNLOAD = 2000 CLOSE = 2001 STATE_GROUP = 2002 PROGRESSBAR_GROUP = 2003 PROGRESSBAR = 2004 PROGRESS_TEXT = 2005 def InitValues(self): self.HideElement(self.PROGRESSBAR_GROUP, True) self.LayoutChanged(self.STATE_GROUP) return True def StopProgress(self): progressMsg = c4d.BaseContainer(c4d.BFM_SETSTATUSBAR) progressMsg.SetBool(c4d.BFM_STATUSBAR_PROGRESSON, False) self.SendMessage(self.PROGRESSBAR, progressMsg) def CreateLayout(self): self.GroupBegin(0, flags=c4d.BFH_SCALEFIT, rows=1, cols=1) self.SetTitle("File Downloader") self.GroupBegin(0, c4d.BFH_SCALEFIT, cols=3) self.GroupBorderSpace(0, 5, 2, 5) self.AddButton(self.DOWNLOAD, flags = c4d.BFH_LEFT, inith = 13, name = "Download") self.AddButton(self.CLOSE, flags = c4d.BFH_RIGHT, inith = 13, name = "Close") self.GroupEnd() if self.GroupBegin(id=self.STATE_GROUP, flags=c4d.BFH_SCALEFIT, rows=0, title="", cols=2, groupflags=0): self.GroupBegin(self.PROGRESSBAR_GROUP, c4d.BFH_LEFT, cols=2) self.GroupBegin(id=0, flags=c4d.BFH_LEFT, cols=1, rows=0) self.GroupBorderNoTitle(c4d.BORDER_THIN_IN) self.AddCustomGui(self.PROGRESSBAR, c4d.CUSTOMGUI_PROGRESSBAR, "", c4d.BFH_SCALEFIT|c4d.BFV_SCALEFIT,200, 8) self.GroupEnd() self.GroupEnd() self.GroupBegin(id=0, flags=c4d.BFH_SCALEFIT, cols=1, rows=0) self.GroupBorderSpace(8,2,0,0) self.AddStaticText(self.PROGRESS_TEXT, flags=c4d.BFH_SCALEFIT, initw=0, inith=16, name="", borderstyle=0) self.GroupEnd() self.GroupEnd() self.GroupEnd() self.GroupEnd() return True def convert_size(self, size_bytes): if size_bytes == 0: return "0B" size_name = ("B", "KB", "MB", "GB", "TB", "PB", "EB", "ZB", "YB") i = int(math.floor(math.log(size_bytes, 1024))) p = math.pow(1024, i) s = round(size_bytes / p, 2) return "%s %s" % (s, size_name[i]) def chunk_read(self, response, chunk_size=8192): total_size = response.info().getheader('Content-Length').strip() total_size = int(total_size) bytes_so_far = 0 progressMsg = c4d.BaseContainer(c4d.BFM_SETSTATUSBAR) progressMsg[c4d.BFM_STATUSBAR_PROGRESSON] = True data = b"" while 1: chunk = response.read(chunk_size) bytes_so_far += len(chunk) if not chunk: break percent = float(bytes_so_far) / total_size percent = round(percent*100, 2) progressMsg[c4d.BFM_STATUSBAR_PROGRESS] = percent/100 self.SendMessage(self.PROGRESSBAR, progressMsg) self.SetString(self.PROGRESS_TEXT, "Downloaded %s of %s bytes (%0.2f%%)\r" % (self.convert_size(bytes_so_far), self.convert_size(total_size), percent)) data += chunk return data def Command(self, id, msg): if id == self.DOWNLOAD: self.HideElement(self.PROGRESSBAR_GROUP, False) self.LayoutChanged(self.STATE_GROUP) # path to save downloaded file on desktop write_path = os.path.join(c4d.storage.GeGetC4DPath(c4d.C4D_PATH_DESKTOP), 'zip_9MB.zip') response = urllib2.urlopen('https://file-examples.com/wp-content/uploads/2017/02/zip_9MB.zip') datatowrite = self.chunk_read(response) with open(write_path, 'wb') as f: f.write(datatowrite) self.HideElement(self.PROGRESSBAR_GROUP, True) self.LayoutChanged(self.STATE_GROUP) self.SetString(self.PROGRESS_TEXT, "") self.StopProgress() if id == self.CLOSE: self.Close() return True def main(): Dlg = MyDialog() Dlg.Open(dlgtype=c4d.DLG_TYPE_MODAL, pluginid=PLUGIN_ID, defaultw=500, defaulth=120) if __name__=='__main__': main()
@indexofrefraction and just in case you have this example from CUSTOMGUI_PROGRESSBAR if you want a more minimal script.
