Texture - Assigning Tex Tag to Select Tag
    On 25/05/2003 at 16:41, xxxxxxxx wrote:
    Cinema 4D Version:   8.100
    Platform:   Windows  ;
    I've created textures in the document and tried to assign them using the texture tag and 'pred tag' to place them after the selection tag I wanted to link them to, but they all just map to the entire object. How do I link to just the correct polygon selection tag?
    Thanks,
    David
    On 26/05/2003 at 00:58, xxxxxxxx wrote:
    Well, this is where some knowledge of how this is done without using plugins comes in handy... ;-)
    Selection tags and texture tags aren't connected by position in the tag list. You need to set the TEXTURETAG_RESTRICTION string of the texture tag to the name of the selection tag. (Search for "TEXTURETAG_RESTRICTION" and you'll find example code in this forum.)
