Save Project As... new project name
I have a modifier plugin that generates a data file, at the same path and same project name.
When I use Save Project As..., I try to get the new project name in theWrite()
, to regenerate my data file, but what I get is actually the original project name.
Can I get the new project name inWrite()
Maybe I'm not accessing the correct document?Bool SomeModifier::Write( GeListNode* /*node*/, HyperFile* hf ) { const auto sceneName = Get()->GetDocument()->GetDocumentPath() + Get()->GetDocument()->GetDocumentName(); return true; }
I understand that I can save anything with the project file, but for the moment we're using a separated file to keep compatibility with other hosts.
maybe I am overlooking or misunderstanding something here, but since
NodeData::Write
is called to write a node, i.e. is being called before the document has been saved, your general logic seems questionable to me. By getting the file path from the document your node is attached to at this point, you will always retrieve the old file path or - and that is probably even more critical - an empty path when the document has not been saved before.Listening for
MSG_DOCUMENTINFO_TYPE
related messages, specifically the post save messagesMSG_DOCUMENTINFO_TYPE_SAVE_AFTER
andMSG_DOCUMENTINFO_TYPE_SAVEPROJECT_AFTER
(and probably more [1]) and execute your save logic from there, seems to be a more reasonable approach to me.Cheers,
zipit
@zipit Yes, my logic may be flawed. If I have more that one node in the scene, I'll save conflicting files.
I didn't know that
Write()
was called before the document is saved. If I'm saving the project with a new name, and while saving it callsWrite()
, I would expect the new project name to be available at that point. Is this saving processing order documented anywhere?
NodeData::Write
is called when a document is about to be saved, to let you serialize any data that you cannot serialize into the data container of yourNodeData
node. The method passes you a pointer to aHyperfile
and expects you to serialize your data into thatHyperfile
and Cinema then incorporates that data into the saved file. After the document has been saved, its in memory representation, including the file path, will be updated. The sister methodsRead
andCopyTo
are expected to be implemented analogously.I do not know what you are planning to do, but you said you have multiple nodes in your scene and there probably will be a user who thinks he really needs 500 of them. Which will lead to 500 save operations at the same time (which doesn't seem very graceful to me). So if you really want to save to (a) separate file(s), it would seem more graceful to at least move the save logic to a separate
MessageData
plugin and combine all of your nodes into one file.I do not think that Maxon has fully exposed the saving process of Cinema, but you can get an idea of it by looking into the link I posted in my first post. They somewhat expect you to use the read/write logic related methods in
NodeData
. Circumventing these methods to save additional data does not seem advisable (unless you know exactly what you are doing), because it handles all the merging and copying (and other stuff that can happen) for you, which you would have to implement by hand if you would circumvent these methods.Cheers,
zipit
hi,
you can use the Message function to catch the message sent before or after the document is saved.
the code below is in python but we have a c++ snippet in our documentation about BaseDocument
You will have to catch MSG_DOCUMENTINFO and check the DocumentInfoData structure you received.def Message(self, node, type, data): if type == c4d.MSG_DOCUMENTINFO: if data['type'] == c4d.MSG_DOCUMENTINFO_TYPE_SAVE_BEFORE: print "save before", data['filename'] if data['type'] == c4d.MSG_DOCUMENTINFO_TYPE_SAVE_AFTER: print "save after", data['filename'] if data['type'] == c4d.MSG_DOCUMENTINFO_TYPE_SAVEPROJECT_BEFORE: print "save project before", data['filename'] if data['type'] == c4d.MSG_DOCUMENTINFO_TYPE_SAVEPROJECT_AFTER: print "save project", data['filename'] return True
Maybe you can use "before" to warn the user that you are about to save something that could take time.
Note also the difference between save and saveProject.Cheers,
Manuel
Saving my project (or Saving As) does not call
MSG_DOCUMENTINFO_TYPE_SAVEPROJECT_*
, onlyMSG_DOCUMENTINFO_TYPE_SAVE_*
.And the document name is not updated on the AFTER message.
Do I need to enable something to callMSG_DOCUMENTINFO_TYPE_SAVEPROJECT_*
hi,
with this code,
i first save my document,
press several time save
save as
save project with assetsave before C:\Users\Manuel Magalhaes\Desktop\temp\testin_saveasset\first_save.c4d save after C:\Users\Manuel Magalhaes\Desktop\temp\testin_saveasset\first_save.c4d save before C:\Users\Manuel Magalhaes\Desktop\temp\testin_saveasset\first_save.c4d save after C:\Users\Manuel Magalhaes\Desktop\temp\testin_saveasset\first_save.c4d save before C:\Users\Manuel Magalhaes\Desktop\temp\testin_saveasset\first_save.c4d save after C:\Users\Manuel Magalhaes\Desktop\temp\testin_saveasset\first_save.c4d save before C:\Users\Manuel Magalhaes\Desktop\temp\testin_saveasset\save_as.c4d save after C:\Users\Manuel Magalhaes\Desktop\temp\testin_saveasset\save_as.c4d save project before C:\Users\Manuel Magalhaes\Desktop\temp\testin_saveasset\save_project_with_asset\save_project_with_asset.c4d save project C:\Users\Manuel Magalhaes\Desktop\temp\testin_saveasset\save_project_with_asset\save_project_with_asset.c4d
as in my code i forgot the save project AFTER the last line is really the after.
as you can see the project name is change before and after.What result do you have ?
cheers,
Manuel
Got it!
documentInfoData->doc->GetDocumentName()
is outdated, butdocumentInfoData->filename
has the new name. Good to detect it's changing.If the
SAVEPROJECT
messages are only called for Save Project with Assets,MSG_DOCUMENTINFO_TYPE
docs should explain it better, as all save options have Project in it.
hi
sorry it wasn't clear enough.
yes sure, doingdocumentInfoData->doc->GetDocumentName()
is the same asdoc->GetDocumentName()
I've updated the documentation with
to be a bit more clear.Cheers,
Manuel
