How to prevent a LinkBoxGui from accepting an object?
I want my LinkBoxes to refuse an object that is already linked by another LinkBox. How can I do this?I came up with a simple script demonstrating where I've gotten stuck:
import c4d from c4d import gui import c4d.plugins LINKBOX_GUI_1 = 2001 LINKBOX_GUI_2 = 2002 class LinkBoxDlg(c4d.gui.GeDialog): doc = c4d.documents.GetActiveDocument() def __init__(self): self.linkboxes = list() def CreateLayout(self): if self.GroupBegin(2003, c4d.BFH_SCALEFIT, 1, 2, "", 0, 0): self.GroupBorderSpace(10, 10, 10, 10) if self.GroupBegin(0, c4d.BFH_SCALEFIT, 2, 1, "", 0, 0): self.AddStaticText(2004, c4d.BFH_LEFT, 0, 0, "Object 1") link1 = self.AddCustomGui(LINKBOX_GUI_1, c4d.CUSTOMGUI_LINKBOX, "", c4d.BFH_SCALEFIT, 0, 0) self.linkboxes.append(link1) self.GroupEnd() if self.GroupBegin(2005, c4d.BFH_SCALEFIT, 2, 2, "", 0, 0): self.AddStaticText(0, c4d.BFH_LEFT, 0, 0, "Object 2") link2 = self.AddCustomGui(LINKBOX_GUI_2, c4d.CUSTOMGUI_LINKBOX, "", c4d.BFH_SCALEFIT, 0, 0) self.linkboxes.append(link2) self.GroupEnd() self.GroupEnd() return True def Message (self, msg, result): if msg.GetId() == c4d.MSG_DESCRIPTION_CHECKDRAGANDDROP: print "*"*50 print "accept: %s"%msg[c4d.LINKBOX_ACCEPT_MESSAGE_ACCEPT] print "control_id: %s"%msg[c4d.LINKBOX_ACCEPT_MESSAGE_CONTROL_ID] # How do I use this control ID to reference the linkbox in the GeDialog? print "element: %s"%msg[c4d.LINKBOX_ACCEPT_MESSAGE_ELEMENT] # How do I use this pointer to find the object in the document? print "msg_type: %s"%msg[c4d.LINKBOX_ACCEPT_MESSAGE_TYPE] print "*"*50 msg[c4d.LINKBOX_ACCEPT_MESSAGE_ACCEPT] = False # Testing editing the message. Why doesn't this affect the linkbox? return gui.GeDialog.Message(self, msg, result) def Command(self, id, msg): if id == LINKBOX_GUI_1: print msg[c4d.BFM_ACTION_VALUE] elif id == LINKBOX_GUI_2: print msg[c4d.BFM_ACTION_VALUE] return True def main(): global dlg dlg = LinkBoxDlg() dlg.Open(c4d.DLG_TYPE_ASYNC, defaultw=300, defaulth=100) if __name__=='__main__': main()
I am not understanding how to use the pointers or how to edit the
message. Once I know how to get the linkbox's proposed linked object and how to accept/refuse, I can check the other linkboxes' values to determine whether or not to proceed with the object.Thank you!
I do not know this for sure, but I would assume that
is intended - as its name implies - to be used in description resources only. If you check the corresponding message data in C++, you will also see, that it is clearly tied to descriptions. The message being sent does not necessarily mean, that Cinema will also process your response. There is a lot of stuff that only kind of works inGeDialog
.Cheers,
zipit
Why don't you just check the value stored in the gadget in your
Command()
function (GetLink()
) and change it, if it is not OK (SetLink()
@PluginStudent Thanks for the idea of how to solve this! I was doing what you described before posting my example, but probably making it too complicated. The documentation for the Link gadget describes the pointer
as 'A pointer to a boolean value. Set this value to true to accept the object.' so that sounded like what I needed. I've rewritten the approach you described and have it seemingly working.
