Listing All Renderers
I'm trying to get a list of all available Renderers. The code I have below only works with Renderers that have been activated:import c4d from c4d import gui from collections import namedtuple RenderEngine = namedtuple('RenderEngine', 'id name') def getRenderEngines(): rd = doc.GetFirstRenderData() renderEngines = [RenderEngine(0,"Standard")] while rd: bvp = rd.GetFirstVideoPost() bvpType = bvp.GetType() bvpName = bvp.GetName() renderEngines.append(RenderEngine(bvpType,bvpName)) rd = rd.GetNext() for reng in renderEngines: print reng def main(): getRenderEngines() c4d.EventAdd() if __name__=='__main__': main()
Because I have changed my document's renderer to Hardware OpenGL, the above code prints the following, but leaves out the others in the screenshot...
RenderEngine(id=0, name='Standard') RenderEngine(id=300001061, name='Hardware OpenGL')
How can I get all of the renderers? Thank you!
Hi, I confirm, a render data only store the current setting for the current render.
However, there is some special condition, and especially the standard render is not registered as a render and really hardcoded.
So here how to retrieve the exact same content than what is available in the render setting windows.import os import c4d def GetRenderData(): # Hardcoded ID IDS_RM_ENGINE = 17000 + 596 IDS_RM_ENGINE_OPENGL = 17000 + 599 # Load render resource c4dFolder = os.path.dirname(c4d.storage.GeGetStartupApplication()) resDir = os.path.join(os.path.dirname(c4dFolder), "resource", "modules", "c4dplugins") res = c4d.plugins.GeResource() res.Init(dir) res.InitAsGlobal() # Standard is special, and maunually added renderEngine = [] renderEngine.append({"id": c4d.RDATA_RENDERENGINE_STANDARD, "name": res.LoadString(IDS_RM_ENGINE)}) # Physical is always the second entry bs = c4d.plugins.FindPlugin(c4d.VPxmbsampler, c4d.PLUGINTYPE_VIDEOPOST) if bs is not None: renderEngine.append({"id": c4d.VPxmbsampler, "name": bs.GetName()}) # PreviewHardware always the third, but here only if OpenG: is active if bool(c4d.GeGetCinemaInfo(c4d.CINEMAINFO_OPENGL)): renderEngine.append({"id": c4d.RDATA_RENDERENGINE_PREVIEWHARDWARE, "name": res.LoadString(IDS_RM_ENGINE_OPENGL)}) # List all videopost pluginList = c4d.plugins.FilterPluginList(c4d.PLUGINTYPE_VIDEOPOST, True) for plugin in pluginList: # Already added stuff, so dont had then 2 times if plugin.GetID() in (c4d.RDATA_RENDERENGINE_PREVIEWHARDWARE, c4d.VPxmbsampler): continue # If the plugin is not a render, continue if not plugin.GetInfo() & c4d.PLUGINFLAG_VIDEOPOST_ISRENDERER: continue renderEngine.append({"id": plugin.GetID(), "name": plugin.GetName()}) return renderEngine for renderEngine in GetRenderData(): print renderEngine
aside from the fact that your code does not return all render engines, but the name of all
BaseVideoPost
nodes, which would also include anything else that can be a post effect, I think the general approach is flawed. Trying to arbitrarily identify any installed render engine is unnecessarily complicated, as you can easily exhaustively enumerate them. Either gather the plugin ids of all render engines and check for these or simply compile a list renderer names and browse the plugin nodes looking for these names - trading the risks of a name based identification for the hassle of dealing with integer based identification.Cheers
zipit
Well, what is a renderer?
If a renderer is a VideoPost-plugin with the flag PLUGINFLAG_VIDEOPOST_ISRENDERER, then you can simply check all registered video post plugins:
pluginList = c4d.plugins.FilterPluginList(c4d.PLUGINTYPE_VIDEOPOST, True) for plugin in pluginList: info = plugin.GetInfo() if info & c4d.PLUGINFLAG_VIDEOPOST_ISRENDERER: print plugin print("is renderer")
@m_adam You are a genius - I am in awe!
Thank you everyone for the help!
