Hello, I'm trying to add multi-language support in my plugin.
I currently have the strings hardcoded in the GeDialog's CreateLayout method like this:
self.AddStaticText(self.HELP_ID, c4d.BFV_BOTTOM | c4d.BFV_SCALE | c4d.BFH_LEFT, 0, 0, "Help")
All of the strings are labels for UI menu commands and gadgets. I understand that the best practice is to put the UI strings into folders within a 'res' folder like so:
res └ strings_en-US └ c4d_strings.str └ strings_fr-FR └ c4d_strings.str
My issue is I don't know how to use the STRINGTABLE in the .str with my Python CommandPlugin. Here's an example of the c4d_strings.str content:
c4d_strings.str (strings_en-US)
STRINGTABLE { IDS_TEST "Test Plugin"; TITLEVIEW_ID "Test - View"; HELP_ID "Help";} }
c4d_strings.str (strings_fr-FR)
STRINGTABLE { IDS_TEST "Test Plugin"; TITLEVIEW_ID "Test - Vue"; HELP_ID "Aide"; }
Please forgive all of these questions:
Thank you so much!
Hi, @blastframe as @PluginStudent pointed you should use GeLoadString.
To make GeLoadString working, you should use as you already did, the .str file but also the c4d_symbols.h so this way Cinema 4D can link the ID you provided in the str file to an actual int value.
c4d_symbols.h
int
res └ c4d_symbols.h └ strings_en-US └ c4d_strings.str └ strings_fr-FR └ c4d_strings.str
enum { IDS_TEST = 10000, TITLEVIEW_ID, // This will have id 10000 + 1 HELP_ID, // This will have id 10000 + 2 // End of symbol definition _DUMMY_ELEMENT_ };
However, due to the nature of Python, the int value defined in the c4d_symbols.h is not ported to python so you have to redefine it in your python code as well.
And here is how to use it in your pyp file. This needs the __res__ to be defined, this is done automatically, for more information see Issue with registering a ToolData.
print c4d.plugins.GeLoadString(10000) # Will print the str value of IDS_TEST
Finally, note that these Symbol IDs must be unique through all Cinema 4D so instead of IDS_TEST is would recommend you rename it with BLASTFRAME_IDS_TEST .
IDS_TEST
BLASTFRAME_IDS_TEST
Cheers, Maxime.
GeLoadString() is the way to go. You actually find plenty of examples of GeLoadString() being used in the C++ code base (e.g. asynctest.cpp) and this doc: String Manual (Classic).
GeLoadString()
Since this topic is older than a week I marked is as closed, but feel free to reopen it if you have further questions.
Cheers, Maxime
@m_adam Hi Maxime! I wanted to make sure I had all of my strings before implementing this. I am very grateful for your help. I will come back to this thread soon! Thank you!
@m_adam I got it working with your help! Thank you so much. I have a couple more questions (more for advice really):
I don't think there are any official "tools". But the docs describe how to handle unicode (Dialog Layout
The encoding is 7-bit ASCII with other characters encoded as \uHHHH. For example 'Natürlich' is written 'Nat\u00fcrlich'. Byte-order marks are not used.
