Recalculate Plugin Object Cache
I have a plugin object that contain an another plugin object, and I want to clone the cache of the child object into the parent object. the problem is when I make changes in the child object parameters the change is not updated immediately in the parent object until I select it.
So , I thought to add a Python Tag to the parent object to trigger the Cache recalculation from the Python Tag.
def GetVirtualObjects(self, op, hh): child = op.GetDown() if not op.GetDown() : return c4d.BaseObject(c4d.Onull) child_cache = child.GetCache() dirty = op.CheckCache(hh) or op.IsDirty(c4d.DIRTY_DATA) if not dirty : return op.GetCache(hh) ...
Thanks.
I am not quite sure for what you are actually asking, but if you have two objects
A
andB
, where the cache ofA
is dependent onB
, you have to turn off (or more precisely not turn on) the cache optimization forA
and incorporate the state ofB
in the evaluation of if the cache ofA
has to be rebuild or not (taking place inGetVirtualObjects
). How you analyzeB
depends on what you want to do, you can useC4DAtom.GetDirty()
onB
in most cases and compare it against the last checksum value you have encountered and stored inA
. In more exotic scenarios you might have to cache the known data ofB
inA
and compare against this data on the next call ofGVO
.Cheers,
zipit
Hi @mfersaoui, thanks for reaching out us.
With regard to your request I would actually consider to use the GetAndCheckHierarchyClone() which should work out of the box.
Something like this, should work
def GetVirtualObjects(self, op, hh): child = op.GetDown() if child is None: print "Object is supposed at least a child" return c4d.BaseObject(c4d.Onull) dirty = op.CheckCache(hh) or op.IsDirty(c4d.DIRTY_DATA) if not dirty : return op.GetCache(hh) resGCHC = op.GetAndCheckHierarchyClone(hh, child, c4d.HIERARCHYCLONEFLAGS_ASIS, True) if resGCHC['dirty'] == True: return resGCHC['clone']
Hi @r_gigante, @zipit,
I'm creating something like the following code. I tried to use the GetAndCheckHierarchyClone, this works but the cloner object became to slow to calculate. For this reason I used the following solution:
def __init__(self): pass #self.SetOptimizeCache(True) def GetVirtualObjects(self, op, hh): instance = op.GetDown() if instance is None: return c4d.BaseObject(c4d.Onull) dirty = op.CheckCache(hh) or op.IsDirty(c4d.DIRTY_DATA) instance_dirty = instance.IsDirty(c4d.DIRTY_DATA) dirty |= instance_dirty if not dirty: return op.GetCache(hh) cloner = c4d.BaseObject(c4d.Onull) count = 3 n = 0 while n < count: instance.GetCache().GetClone().InsertUnder(cloner) n += 1 cloner.Message(c4d.MSG_UPDATE) return cloner
So, by just deactivating the SetOptimizeCache and cloning only the cache of the instance object the cloner object calculate is become to fast. The unique problem now is the cloner object is return the cache of previous modification on the instance object. This is perceptible only with bool parameters.
Example:
When I check a bool parameter of the instance object, the cloner return the result of the previous state of the bool parameter. but if I mouseover the cloner in the Viewport or I select it object manager this update the cloner object.Thanks
This post is deleted!
