Finding duplicate materials - Octane Render
Hi all,
I'm currently trying to find duplicate materials by comparing the values of its BaseContainer parameters.
Unfortunately, I can see that exact same objects have different memory addresses and it will always fail.<c4d.BaseShader object called 'Absorption Medium/Absorption Medium' with ID 1029510 at **0x00000223328084F0**>
<c4d.BaseShader object called 'Absorption Medium/Absorption Medium' with ID 1029510 at **0x00000223328085F0**>
Have the following code:
import c4d def get_data(mat): """ Get the parameters from the materials container and return a list. """ data = mat.GetDataInstance() mat_params = [] for i in range(len(data) - 1): index = data.GetIndexId(i) try: mat_params.append(data[index]) except AttributeError: continue return mat_params def compare_data(lst_a, lst_b): """ Compare the data between lists a and b. If data is the same, than material is a duplicate. """ zipped = zip(lst_a, lst_b) for params in zipped: if params[0] != params[1]: return False return True def main(): mat_lst = doc.GetMaterials() duplicate_materials = [] for a, mat_a in enumerate(mat_lst): data_a = get_data(mat_a) for b, mat_b in enumerate(mat_lst): if a != b: data_b = get_data(mat_b) data_difference = compare_data(data_a, data_b) if data_difference: duplicate_materials.append(mat_b) assert not duplicate_materials, "You have {0} materials duplicated! " \ "See list below:\n\n{1}".format(len(duplicate_materials), ", ".join(mat.GetName() for mat in duplicate_materials)) if __name__ == '__main__': main()
Wonder if you have any advice on how to deal with this issue or perhaps a different approach to duplicate objects.
Thank you in advance!
Andre
Not sure if it helps in your case, but
BaseMaterial
has a Compare() function.
Hi @PluginStudent ,
Thank you very much for your help!
I should have mentioned that it needs to work for any render engine. Currently we use Octane and I think the
Compare()
function may just be related to Cinema native materials (I may be wrong!), as from my previous tests it did not work.So I'm trying to go with data comparising, just in case.
Let me know if you find another solution please!
Thank you again!
If you have two materials, and both use a certain shader, then these shader are (as you have noticed) still different objects at different memory addresses. Since C4D classes are mutable (other than, say, the Python integer class) Python cannot reuse the object. After all, the user may at any time change a parameter in the shader used by material 1, but not the equivalent shader used by material 2, resulting in 2 different shader instances.
With all hierarchical structure based on dynamic objects, you need to perform the comparison recursively (deeply), or you will run into the issue that data identity is not necessarily object identity. If you're lucky, your classes contain a deep comparison function already; otherwise, you need to go into the objects-to-compare and continue on that level, all the way down.
Hi @Cairyn,
Thank you very much for your thorough explanation!
That makes a lot a sense to me and seems to be the way to proceed with this.
I will give it a go and see where it leads me.Have a good one and thanks again!
Hi all,
So I after a bit of tinkering and based on what @Cairyn explained, this is the outcome.
Please do let me know if I can improve on something.My only doubt is regarding the
PyCObject
types and what to do with it. In the code below I'm just ignoring it as I can't do anything with it anyway in a Python data context (I think!) and it doesn't seem to create any unusal cases when comparing the materials values.import c4d def get_data(data, lst): """ Get the parameters from the materials container and return a list. """ for i in range(len(data) - 1): index = data.GetIndexId(i) try: if isinstance(data[index], (c4d.BaseShader, c4d.BaseTime)): sub_data = data[index].GetDataInstance() get_data(sub_data, lst) else: if type(data[index]).__name__ == 'PyCObject': continue lst.append(data[index]) except AttributeError: continue return lst def compare_data(lst_a, lst_b): """ Compare the data between lists a and b. If data is the same, than material is a duplicate. """ zipped = zip(lst_a, lst_b) for params in zipped: if params[0] != params[1]: return False return True def main(): mat_lst = doc.GetMaterials() duplicate_materials = [] for a, mat_a in enumerate(mat_lst): data_a = get_data(mat_a, []) for b, mat_b in enumerate(mat_lst): if a != b: data_b = get_data(mat_b, []) data_difference = compare_data(data_a, data_b) if data_difference: duplicate_materials.append(mat_b) assert not duplicate_materials, "You have {0} materials duplicated! " \ "See list below:\n\n{1}".format(len(duplicate_materials), ", ".join(mat.GetName() for mat in duplicate_materials)) if __name__ == '__main__': main()
Hope this helps anyone else!
Cheers!
Thanks @AndreAnjos for coming up with the final code.
Two notes:
- first reading your initial question: was hard to understand what you meant with regard to "duplicated" materials and how you were defining the equality among twos. Standing on the solution you presented, basically two materials are identical only and only if the values of all their parameters are equal
- second the
get_data
function expects two arguments, whilst, in your code, only one is given to both calls in themain
Finally, as pointed out by @PluginStudent,
BaseMaterial::Compare()
actually does exactly what you're trying to achieve, and any material implementing MaterialData can be checked via this method belonging to the BaseMaterial class to which they inherit from (independently from the rendering engine they belong and assuming they following up with the best practice of storing data in BaseContainers)The Compare actually does:
- compares BaseChannels
- compares BaseContainers
- compares Ckeys found in CCurves belonging to CTrack.
Only when these three checks give all positive results, the two materials are considered identical
Best, R
Hi @r_gigante,
Thank you very much for pointing stuff out!
Apologies for this! Should have been more specific with my description.
second the get_data function expects two arguments, whilst, in your code, only one is given to both calls in the main.
This has now been updated! Thanks for pointing it out.
The Compare actually does:- compares BaseChannels
Great! Thank you for your explanation! Did not know if that would be the case since my tests were not coming with the results. So will give it another go!
Thanks again!
Hi @r_gigante
I must be really stupid here, but can't have the result you are saying with this function.
A simple test of having 2 supposedly duplicate materials and still returnsFalse
.import c4d def main(): mat_lst = doc.GetMaterials() result = mat_lst[0].Compare(mat_lst[1]) print(result) if __name__ == '__main__': main()
I must be missing something very obvious and I can't figure it out.
Thanks for your help!
Also as an update!
I've been talking with a couple of artists here and after a few simple tests using the Delete Duplicate Materials in Cinema R19 and R21, does not work as well.Is this a common issue?
Thanks!
Hi @AndreAnjos, looking at the code it seems I've spotted a bug but it's still under investigation. I'll let you know if that's the case and report back.
Cheers, R
Hi @r_gigante,
Any luck with this? It's no rush at all for us, just curious if you have an update
Cheers!
Andre
Hi @AndreAnjos, no updates so far.
Cheers, R.
