Unable to Add Objects for User Data with In/Exclusion Data Type
Hi I'm trying to Add Objects for
User Data
withIn/Exclusion Data Type
but it doesn't seem to work.
It doesn't also error out. It's the same code I used for theIn/Exclusion Data Type
for theSelection Object
, which works.You can see the illustration here for
Selection Object
which works:
https://www.dropbox.com/s/e0zi466697btn8r/c4d213_unable_to_add_object_to_user_data_inexclusion_list01.mp4?dl=0You can see the illustration here for
User Data
which doesn't work:
https://www.dropbox.com/s/2kur2ndwjcdq35k/c4d213_unable_to_add_object_to_user_data_inexclusion_list02.mp4?dl=0Here is the code so far:
import c4d from c4d import gui def main(): tag = op.GetTag(1022749) bc = c4d.GetCustomDataTypeDefault(c4d.CUSTOMDATATYPE_INEXCLUDE_LIST) bc[c4d.DESC_NAME] = 'obj_list' bc.SetLong(c4d.IN_EXCLUDE_FLAG_NUM_FLAGS, 1) bc.SetLong(c4d.IN_EXCLUDE_FLAG_INIT_STATE, 1) bc.SetLong(c4d.IN_EXCLUDE_FLAG_IMAGE_01_ON, 1018640) bc.SetLong(c4d.IN_EXCLUDE_FLAG_IMAGE_01_OFF, 1018641) desc_ID = tag.AddUserData(bc) # Add userdata container obj_list_content = c4d.InExcludeData() obj_list_content.InsertObject(doc.SearchObject('Sphere'), 1) obj_list_content.InsertObject(doc.SearchObject('Cube'), 1) obj_list = tag[c4d.ID_USERDATA,desc_ID[1].id] obj_list = obj_list_content # Execute main() if __name__=='__main__': main()
you are assigning a copy of your in/exclude list to obj_list and override the copy only.# you are assigning a copy of your in/exclude list to obj_list. obj_list = tag[c4d.ID_USERDATA,desc_ID[1].id] # you override the copy obj_list = obj_list_content
you can instead override the userdata itself. And if you look, that's what you are doing in the first example.
tag[c4d.ID_USERDATA,desc_ID[1].id] = obj_list_content c4d.EventAdd()
Manuel
Thanks for the explanation. Works as expected.
