Solved Integrating a CallCommand() with Built-In Save Dialog?
I'm trying to create a script that
  1. Exports All Skin Weights in the Scene to an External File
  2. Name Each file with an Object Name
I want to piggy back on C4D's Save Weights (under the Weight Manager) with the c4d.CallCommand(1028186)
The problem is I don't know how to perform the naming of each file.
When I execute c4d.CallCommand(1028186), I have no access to the Save Dialog.
Is there a way around this? Or should I just create my own weight saver (ouch)?
it's not possible to bypass that dialogbox or set a filename.
Using CallCommand is like a user pressing a button in the UI, so if you have a DialogBox, you are blocked and you must use something else.
It is possible to retrieve all the weight for all joints.
some doc that could help you :
on the tag function you got the GetWeightMap that is interesting.
You can export that to a binary format of you own or an xml, it's up to you.
Manuel.
MAXON Registered Developer
@m_magalhaes
Thanks for the confirmation.
