Dialog Freezes when checking for Message()
I'm trying to create a separate slider for my finger controls.
The slider is at default 0. Then if you move it, the change will be applied to the finger control. Then the slider will be set again to 0.However, I'm having a problem as it freezes when checking for
c4d.MSG_CHANGE
.You can see the problem here:
https://www.dropbox.com/s/88vmuzivqylbh1x/c4d207_dialog_freezes_when_checking_for_msg.mp4?dl=0You can check the working code here:
# For the Add Edit Slider reset to Zero import c4d from c4d import bitmaps, documents, gui, plugins, threading, utils class MyDialog(c4d.gui.GeDialog): def __init__(self): self.finger_B_01_L_con = doc.SearchObject('finger_B_01_L_con') def CreateLayout(self): self.AddEditSlider(id=303030, flags=c4d.BFH_SCALEFIT, initw=80, inith=0) return True def InitValues(self): self.SetDegree(303030, 0.0, min=-45, max=45, step=0.01, min2=0.0, max2=0.0) return True def Message(self, msg, result): if msg.GetId() == c4d.MSG_CHANGE: if self.AddEditSlider.GetFloat(303030) != 0: rotation_current = self.finger_B_01_L_con.GetRelPos() rotation_modify = self.GetFloat(303030) rotation_new = rotation_current + rotation_modify self.finger_B_01_L_con.SetRelPos(rotation_new) # Set the AddEditSlider Back to Zero self.InitValues() return True if __name__ == "__main__": dlg = MyDialog() dlg.Open(dlgtype=c4d.DLG_TYPE_ASYNC)
Without explicitly testing: You are changing the slider (InitValues) while you are still checking the message. Which probably generates a new message, which calls Message again, etc.
The least thing you can do is NOT call InitValues if the slider is already at 0.0.
I'm not sure anyway whether the code will do what you want, as any tiny movement of the slider will accumulate into a finger rotation (even while the user is still dragging the slider). I bet it would just start spinning out of control, or become unresponsive...
I might be overlooking something here, but shouldn't raise
in the conditional statement anAttributeError
since themethod type
has no attribute calledGetFloat
.Cheers
zipit
Thanks for the response
Oh you mean loop? I didn't think of that.
But it should already do this: "NOT call InitValues if the slider is already at 0.0."
since if I have aif self.AddEditSlider.GetFloat(303030) != 0:
line.
If its already at zero, theInitValues
shouldn't be called.@zipit
That might be so but for some reason, it does not give an error to the console. It just freezes.
Hi @bentraje
First, you should always call re-route the message to the parent (as it's written in the doc) GeDialog.Message. In some situation you may want to kill the event but they are very very limited and you should call GeDialog.KillEvents and return True, but this is really really rare. Since pretty much everything is handled by the parent (ask for close, ask for movement, ask for change, etc....) So if you don't re-route it freezes.Secondly, there is an issue in SetDegree since there is no min2 or max2 parameter see GeDialog.SetDegree.
Moreover, I'm not sure which event you are trying to catch with MSG_CHANGE, since it sent to objects when they have changed not Dialog.
Thanks for the response.
RE: always call re-route the message to the parent
By that, do you mean changing the
to
return GeDialog.Message(self, msg, result)
?RE: GeDialog.KillEvents
Ok Added.RE: there is an issue in SetDegree since there is no min2 or max2 parameter
Ok. Changed toSetFloat
instead. By the way, in the documentation, there isGetFloat
but noGetDegree
. Is this normal?RE: I'm not sure which event you are trying to catch
I'm trying to catch thedragging of the slider and release
. So the slider changing values.Here is the revised code. It no longer freezes but it doesn't catch the event:
# For the Add Edit Slider reset to Zero import c4d from c4d import bitmaps, documents, gui, plugins, threading, utils class MyDialog(c4d.gui.GeDialog): def __init__(self): self.finger_B_01_L_con = doc.SearchObject('finger_B_01_L_con') def CreateLayout(self): self.AddEditSlider(id=303030, flags=c4d.BFH_SCALEFIT, initw=80, inith=0) return True def InitValues(self): self.SetFloat(303030, 0.0, min=-45, max=45, step=0.01, min2=0.0, max2=0.0) return True def Message(self, msg, result): if msg.GetId() == c4d.MSG_CHANGE: if self.AddEditSlider.GetFloat(303030) != 0: rotation_current = self.finger_B_01_L_con.GetRelPos() rotation_modify = self.GetFloat(303030) rotation_new = rotation_current + rotation_modify self.finger_B_01_L_con.SetRelPos(rotation_new) # Set the AddEditSlider Back to Zero self.InitValues() self.KillEvents() return c4d.gui.GeDialog.Message(self, msg, result) if __name__ == "__main__": dlg = MyDialog() dlg.Open(dlgtype=c4d.DLG_TYPE_ASYNC)
@bentraje said in Dialog Freezes when checking for Message():
to
?Yes
Ok Added.I guess you didn't understand what I said previously. There are two cases.
- you don't want the message to be processed by others (e.g. disable default functions such as disabling the right-click or even value change, by removing the dispatch to the Command method so you have to call KillEvents and return True).
- You want the default behavior, so when you change a value, the value will be changed, etc...
In your case do you want to remove default functionality for the Dialog? No, you just want to react to some change, but you want to be transparent, not avoid any change, so don't call KillEvents and return True.
but noGetDegree
. Is this normal?Yes because SetDegree only changes how the internal float value is represented in the Dialog it's written in the documentation of GeDialog.SetDegree.
. So the slider changing values.Command method will be called in both cases so I don't really know why you want to deal with Message.
However, if you want more precise control, then I agree that Message should be used, but you should listen for either
BFM_INTERACTSTART: (Sent when the user interaction start)
BFM_INTERACTEND: (Sent when user interaction ends.)Or BFM_ACTION to get value while the dragging occurs.
For more information, look at the C++ GeDialog Gadget Interaction Manual.
And as @zipit already pointed you, there is no
. GetFloat is a method from GeDialog not for the gadget.Cheers,
@bentraje Try the BFM_xxx messages for gadget interaction, not MSG_CHANGE.
(and no KillEvents in your case)
Duh, I need to type faster.
Thanks for the inputs and explanation.
The code functions but even if I use theBFM_ACTION
where it gets updated for every dragging, the controller is only updated at the release of slider. Compared to the Attribute Manager where the changes are interactive.I also tried the
BFM_ACTION_INDRAG
andBFM_ACTION_VALCHG
but I get the same result.You can see the problem here:
https://www.dropbox.com/s/05tq12uozc1acjj/c4d207_dialog_freezes_when_checking_for_msg02.mp4?dl=0Apologies for the trouble.
Here is the working code:
# For the Add Edit Slider reset to Zero import c4d from c4d import bitmaps, documents, gui, plugins, threading, utils class MyDialog(c4d.gui.GeDialog): def __init__(self): doc = c4d.documents.GetActiveDocument() self.finger_B_01_L_con = doc.SearchObject('finger_B_01_L_con') def CreateLayout(self): self.AddEditSlider(id=303030, flags=c4d.BFH_SCALEFIT, initw=80, inith=0) return True def InitValues(self): self.SetFloat(303030, 0.0, min=-45, max=45, step=0.01, min2=0.0, max2=0.0) return True def Message(self, msg, result): if msg.GetId() == c4d.BFM_ACTION: if self.GetFloat(303030) != 0: rotation_current = self.finger_B_01_L_con.GetRelRot()[2] rotation_modify = c4d.utils.DegToRad(self.GetFloat(303030)) rotation_new = rotation_current + rotation_modify self.finger_B_01_L_con[c4d.ID_BASEOBJECT_REL_ROTATION,c4d.VECTOR_Z] = rotation_new c4d.EventAdd() # Set the AddEditSlider Back to Zero if msg.GetId() == c4d.BFM_INTERACTEND: self.InitValues() return True return c4d.gui.GeDialog.Message(self, msg, result) def Command (self, id, msg): return True if __name__ == "__main__": dlg = MyDialog() dlg.Open(dlgtype=c4d.DLG_TYPE_ASYNC)
Cause in your BFM_ACTION you call EventAdd, instead call
c4d.DrawViews(c4d.DRAWFLAGS_ONLY_ACTIVE_VIEW | c4d.DRAWFLAGS_NO_THREAD | c4d.DRAWFLAGS_NO_REDUCTION | c4d.DRAWFLAGS_STATICBREAK)The main issue is that EventAdd, as its name suggests adds an update event to the event stack, this will be processed when it got the time (meaning when the main thread is free) but since you are in a drag operation, the main thread is occupied by this drag operation.
While DrawViews, will as the name said, draw the view right now (take care it's pretty heavy since it implies a call to ExecutePass) so regarding the scene, it may be slow.
Thanks @m_adam.
First time using thec4d.DrawViews()
It works as expected. Thanks for the introduction.
